EK disc brake conversion(which lines do i need)
Old Nov 15, 2005 | 07:04 PM
dingle's Avatar
Default EK disc brake conversion(which lines do i need)
I am swapping 96 civic drums with 99 gsr discs. I read the archives about if u use the integra calipers u have to use the integra lines, is that correct?
Is there more than one main brake line on each side or is there a couple of brake lines on each side? Which ones do i need? The conversion doesn't come with the lines!!
I use the 99-00 si e-brake cables correct?
Old Nov 15, 2005 | 07:31 PM
2000DX's Avatar
Default Re: EK disc brake conversion(which lines do i need) (dingle)
There is only 1 line on each side.
and yes, you would use the 99-00 Si e-brake cables.
-edit- Sorry, I just went over the thread in the FAQ. Sorry for the misinformation, it looks like you would need the Integra rear brake line.
Modified by 2000DX at 11:40 PM 11/15/2005
Old Nov 15, 2005 | 07:36 PM
cambodia got civics too's Avatar
Old Nov 15, 2005 | 07:44 PM
RedEK9's Avatar
Default Re: EK disc brake conversion(which lines do i need) (2000DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000DX &raquo;</TD></TR><TR><TD CLASS="quote">You would use the 99-00 Si rear brake line. There is only 1 line on each side.
and yes, you would use the 99-00 Si e-brake cables.</TD></TR></TABLE>
What he said!
Old Nov 15, 2005 | 07:56 PM
dingle's Avatar
In the faq's archive it says that the lines on an si will not work on integra calipers because the ends on them are different?
Old Nov 15, 2005 | 08:33 PM
EL Vap133's Avatar
Correct!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dingle &raquo;</TD></TR><TR><TD CLASS="quote">In the faq's archive it says that the lines on an si will not work on integra calipers because the ends on them are different?</TD></TR></TABLE>
What year Si?
elnoyl
May 6, 2009 05:38 PM
godskrilla
Mar 23, 2008 01:18 AM
813EK
Jan 22, 2008 08:02 AM
01geeser
10
Mar 26, 2007 05:05 PM
