where to put a greedy catch can?
mines not a greddy, but here is a pic of where i put mine, kinda hard to see, its right behind the resevoir bottle.
make sure where you put it, it is lower than the pcv valve so you dont get any blockage in the lines goin to the catch can.
I was thinking about putting mine where the windshield wiper bottle is located on the front right. I am going to remove the windshield wiper bottle...
i was gonna take out my stock char. canister and put it there right under the fuel filter,or make a bracket around the fuel filter area....?not to sure right now.anymore pics? of anyone else's setup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danteisme »</TD></TR><TR><TD CLASS="quote">if it was up higher, the oil/oil fumes would have gravity workin against it tho.</TD></TR></TABLE>
i don't know about all motor setups, but for f/i setups, it needs to be high. if you want to read a really good thread about this. search for threads by "dasher" and it'll find all the info about this.
i know it's hard to find a good place in integras to place a catch can. it seems it is easiest if you do a wire tuck or something so that all the wires are gone and then it looks like you have more room. at least around the shock tower so you can place it there. if not, you can either relocate the battery or make some room against the firewall. i haven't really decided where to put mine, but i'm leaning towards the firewall if i can move things around. if you just need to vent a little pressure, just put it in a low location. fashion > function right?
ok, here's a pic i found in appearance/cosmetics from the orlando t-i meet. thanks to Nitrous151 for the pic
edit: if the picture doesn't show, right click it and grab the url to open in another window.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nataku »</TD></TR><TR><TD CLASS="quote">sorry for the highjack... what does a catch can do?</TD></TR></TABLE>
a catch can is made to work like the pcv system on our honda cars. here's are threads by dasher
who explains how our stock pcv system works. they're the same.
in the force induction section-> https://honda-tech.com/zerothread?id=697498
in the tech/misc section-> https://honda-tech.com/zerothread?id=697502
and here is the thread to his result for force induction cars.
https://honda-tech.com/zerothread?id=1199935
who explains how our stock pcv system works. they're the same.in the force induction section-> https://honda-tech.com/zerothread?id=697498
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98IntegraLSNonVtec »</TD></TR><TR><TD CLASS="quote">this is a newbie question but what is the purpose of a catch can?</TD></TR></TABLE>
I think it's for releasing pressure (crankcase ventilation) from your engine by taking oil to keep the oil level at a good level. It's kind of just like the name, "catch can"; it's a can that catches some oil to keep the PCV down so seals and gaskets don't eventually wear out or break.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01SILVERDC2 »</TD></TR><TR><TD CLASS="quote">i have a couple of area's in mind but more the better
if you have pics post them
im going to put mine right in the little area where the Airbox used to be.
</TD></TR></TABLE>im going to put mine right in the little area where the Airbox used to be.
Brandon EM1
Mar 12, 2004 01:21 PM
Count Blah
32
Aug 10, 2003 12:38 AM
b16awarrior
Sep 21, 2001 09:27 AM
