quick question about sticky stuff on botom of da
Old Nov 15, 2005 | 04:40 PM
watsvtecEK's Avatar
Default quick question about sticky stuff on botom of da
i herd that this stuff can be chiped off. has anybody done this? how much weight will the car lose? what is the pourpose of it?
thanks
Old Nov 15, 2005 | 04:59 PM
FrOsTwHiTeDC4's Avatar
Default Re: quick question about sticky stuff on botom of da (b18tegra)
your talking about the sound deadner stuff right? if so, i used a screwdriver and hammer...took me awhile but i got it out...i hear you can you dry ice to help out. search around for it.
Old Nov 15, 2005 | 06:32 PM
projectTeG's Avatar
are you talking about the undercoating on the bottom of the chassis or the "tar" on the cabin? the tar you can remove with a heat gun and a chisel and hammer....or you can use dry ice, but be careful you can damage your undercoating. i believe the tar weights around 40 lbs. if you are talking about the undercoating you dont want to remove that, it protects your under body.
577HondaPrelude
29
Nov 27, 2006 10:07 AM
h22mark
Oct 1, 2003 08:15 PM
