2000 Mustang Problems... can't push back the rear pistons
i got a little problem, its 2000 mustang and the rear calipers pistons wont go back,
i've tried
i tried renting those tools to turn the piston back in and still nothing its turning but its not really going back in...
any suggestions,,
one of the rear pads went to the metal on metal contact, dont know if that could have seized the caliper..
any suggestions?
i've tried
any suggestions,,
any suggestions?
Make sure your ebrake is not engaged. Otherwise if the piston is spinning it should retract. Watch your brake fluid reservoir and see if it over flows, if it does take some old fluid out.
finally got it done, i was using one of those cheap $4 universal piston pusher, i had to get a professional tool, those pistons where really hard,
opening up the bleeder screw wasn't helping, i had to unbold the line then i got it after a lot of cursing!
thanx guys.
thanx guys.
HondaJon
20
May 30, 2003 07:42 PM
