installed new starter. car won't start
Old Nov 15, 2005 | 02:15 PM
baboonstyle's Avatar
Default installed new starter. car won't start
well, I took my starter to autozone and it failed. I have a jdm b16 siR II and I did a search and someone said they used a 99 si starter on their 1st gen b16 and it worked. I tried it and it didn't fit. the screws were off by 1 millimeter. they typed in the part number that was on my starter but they didn't have it in stock. he looked up a gsr starter which they had, so I tried that one. it fits, but when I go to start the car, nothing happens. no click, nothing. with jumper cables attached, still nothing, not even clicking from the starter. im pretty sure it's hooked up right. I took a volt meter to the pos and neg on the starter and it shows power. only 12v though. the starter is tight to the tranny. help please.
Modified by baboonstyle at 8:21 PM 11/17/2005
Old Nov 15, 2005 | 02:17 PM
8herout's Avatar
Default Re: installed new starter. car won't start (baboonstyle)
check your grounds
Old Nov 15, 2005 | 02:19 PM
Default Re: installed new starter. car won't start (8herout)
all grounds have been sanded down. can you hook up jumper cables directly to the starter? i think i read that somewhere
Old Nov 17, 2005 | 11:19 AM
bump...still not starting.
Old Nov 17, 2005 | 11:37 AM
Andres-eh2's Avatar
grab a piece of ground wire and place if from the battery negative to a metal bracket on the starter. I had my chassis to tranny ground fail on me and worked when i tried this
Old Nov 17, 2005 | 11:52 AM
postman's Avatar
there are 3 terminals on your starter bat term motor term and s switch from ignition, you nned power ats switch to bet power at b terminal to transfer to motor terminal, the b term and motor term work in conjunction from disc inside your solenoid. if that makes sense to you you should be able to figure out, also check your neutral safety relay, locates in your s switch wire or manual be sensor under your clutch pedal
Old Nov 17, 2005 | 05:57 PM
hatchi's Avatar
try pushstarting your car if it works then something is wrong with your wiring or starter.
Old Nov 17, 2005 | 06:06 PM
dropcivic's Avatar
Default Re: installed new starter. car won't start (hatchi)
Why don't you see if you have a starter signal coiming into the starter. CHeck at the female plug that goes into the starter. I am betting that the clutch switch pad broke. If the clutch switch isn't pressed, you have no signal to the starter so nothing will happen, no engine turning, no clicking, nothing.
Old Nov 17, 2005 | 06:07 PM
civic_driver's Avatar
check your ignition switch and battery
Old Nov 17, 2005 | 06:39 PM
siblueg's Avatar
Default Re: (civic_driver)
fuses or relays
Old Nov 19, 2005 | 02:22 PM
Default Re: (siblueg)
which relay do I check? I checked all the fuses and they are fine. I may have to have them retest the starter.
Jack Murphy
Jun 21, 2017 06:23 PM
big.turbo.daddy
Jun 23, 2015 06:34 PM
SlammedEG6
Aug 28, 2008 04:25 PM
skn181
Mar 23, 2007 06:02 PM
Sukebei Oni
Mar 16, 2003 01:21 AM
