Premature distributor wear and failure
Old Nov 15, 2005 | 02:09 PM
EG6_GUY's Avatar
Default Premature distributor wear and failure
I had a SIR2 motor swap done in Spring of '04. At that time, I had them put on a new Honda cap & rotor, water pump/timing belt, NGK spark plugs/wires, radiator and tune it up. By January, the distributor started making a screeching sound accompanied by some clicking. I took it to my shop and had them replace it with a good used distributor. Its been 10 months or so, and the thing just started screeching/clicking today.
My questions are: Is it common for these distributors to have such a short life span? Am I not doing some sort of maintanance thing? Is there a distributor (GSR, ITR, etc..) that is more durable? Thanks!
Old Nov 15, 2005 | 02:17 PM
Chiovnidca's Avatar
Default Re: Premature distributor wear and failure (EG6_GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6_GUY &raquo;</TD></TR><TR><TD CLASS="quote"> a good used distributor.
My questions are: Is it common for these distributors to have such a short life span? Thanks!</TD></TR></TABLE>
You get what you pay for.
Old Nov 15, 2005 | 02:24 PM
EG6_GUY's Avatar
Default Re: Premature distributor wear and failure (Chiovnidca)
I should probably have said rebuilt distributor. It was not new, it was rebuilt/used.
Modified by EG6_GUY at 10:17 AM 11/16/2005
Old Nov 15, 2005 | 02:26 PM
peacexisxfree's Avatar
honda dizzys are the weakest part of the cars. you need to get yourself a NEW one.
Old Nov 15, 2005 | 02:28 PM
EG6_GUY's Avatar
Default Re: Premature distributor wear and failure (peacexisxfree)
I will. But when I do, should I buy a B16 one or is there a better/stronger Honda distributor?
taguchi09
Jun 11, 2011 04:52 PM
BIGPAPAWACK
10
Aug 23, 2010 11:51 AM
torreypjones
Feb 9, 2007 08:24 AM
92integra-R
Mar 27, 2006 10:23 PM
uNF$@#!
Mar 28, 2004 11:48 PM
