92-95 and 96-00 Civic A/C lines the same?
Old Nov 15, 2005 | 11:46 AM
.Beaver's Avatar
Bloody Beaver
Default 92-95 and 96-00 Civic A/C lines the same?
as the topic states... can I take the lines off my 97 Ex coupe and put them on my 93 EX? They seem to go pretty much the same route around the engine bay.
Old Nov 17, 2005 | 07:00 PM
.Beaver's Avatar
Bloody Beaver
Default Re: 92-95 and 96-00 Civic A/C lines the same? (Leeroy)
I'm the boss. Need the info.
Old Nov 17, 2005 | 07:16 PM
sockvtec's Avatar
try it and find out
Old Nov 17, 2005 | 07:26 PM
.Beaver's Avatar
Bloody Beaver
Default Re: 92-95 and 96-00 Civic A/C lines the same? (sockvtec)
come up to WI and you do it!
Old Nov 17, 2005 | 08:01 PM
Swapped_EG's Avatar
no it won't work. 92 and 93 civic used R12 and the lines are different. 94 and up uses R134. so no it won't work.
Old Nov 17, 2005 | 08:23 PM
.Beaver's Avatar
Bloody Beaver
Default Re: (Swapped_EG)
well how different? because I'm using the WHOLE 97 AC, nothing from R12 era is being used. Are the lines routed different or what?
Old Nov 17, 2005 | 08:28 PM
Cuda70's Avatar
Default Re: (Leeroy)
If you are using 134 stuff, it is interchangable.
The only problem you would have is if you used R12; the fittings are different.
Old Nov 17, 2005 | 08:54 PM
.Beaver's Avatar
Bloody Beaver
Default Re: (Cuda70)
can the 97 evaporator be used in my 93? Not sure if it'll match up correctly with the blower motor/heater core
Old Nov 17, 2005 | 09:54 PM
E.Honda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leeroy &raquo;</TD></TR><TR><TD CLASS="quote">as the topic states... can I take the lines off my 97 Ex coupe and put them on my 93 EX? They seem to go pretty much the same route around the engine bay.</TD></TR></TABLE>
You can....If they will fit.....You will have to use your 97 condensor and swap the goods behind the dash. The fittings on the r12 and 134 are different.
I have the lines you need for the 93...
nightscream
11
Jul 12, 2020 12:10 PM
jedsus
Apr 13, 2007 05:45 PM
Thrillahbeeh
Aug 28, 2006 10:09 PM
aktc167
Feb 25, 2006 07:21 PM
