Horrible acceleration below 2000RPM
Old Nov 15, 2005 | 11:09 AM
SLO Sol's Avatar
Default Horrible acceleration below 2000RPM
so im driving and i take off it hesitates then kinda studders and sounds really bad what could be the problem. it was raining outside i dont know why it does it. it is a GSR motor with 120,000 miles could it be something wrong with the head or block or could it just be i need new plugs and wires? or maybe a distributor?
Old Nov 15, 2005 | 11:19 AM
vtakvtrak's Avatar
Default Re: Horrible acceleration below 2000RPM (D-money CX)
spark plugs, distributor cap + rotor, gm syncromesh, trans flush the usual, have u done the 120K tune up?
Old Nov 15, 2005 | 12:18 PM
postman's Avatar
timing advanced to far maybe
Old Nov 15, 2005 | 12:19 PM
civic_driver's Avatar
time retard, crappy dizzy components, spark plugs, running rich/o2 sensor, etc.
Old Nov 15, 2005 | 12:21 PM
Soccerking3000's Avatar
Default Re: (civic_driver)
its a honda?
Old Nov 15, 2005 | 12:30 PM
b204dr's Avatar
Default Re: (Soccerking3000)
crappy accell under 2k usually means congestion ... ( hence 120k) run some sea foam too !
also seen clogged cats have this effect but through out the whole powerband more
Old Nov 15, 2005 | 07:14 PM
SLO Sol's Avatar
only happens when its cold
Old Nov 15, 2005 | 10:07 PM
Elwuudz's Avatar
If your in this forum because you have a 92-00civic/ Sol then listen to this.
Before going any further..
look at your intake manifold...
locate your fuel rail...
on the driverside there is a metal tube that is shaped like an L sticking out.. close to the fuel rail.
Check to see if a small black tube is connected to this L looking thing.
This tube comes from the intake manifold then connects near the fuel rail.
This signals/regulates fuel pressure at idle and during acceleration.
I've seen the exact same problems you were having in your car with many other 95HB and 93-97 sols. This tube might also have some condensation.. ice forming from cold temps. GSR motor should be no different...
If this doesn't work.. sry
Try looking at your headgasket or if your valve cover is fasten correctly.
Modified by Elwuudz at 3:53 AM 11/16/2005
Old Nov 15, 2005 | 10:13 PM
teknoracing's Avatar
Default Re: (Elwuudz)
Could be cheap gas? WHen was the last time you did a tune up?? How long have you had the swap?? Check your plugs, oil, air filter, etc.
Old Nov 15, 2005 | 10:40 PM
TsukubaDreams's Avatar
Just do a tune up including changing the fuel filter and all shall be well with your ride..... and dont forget to change the fuel filter... sorry i couldnt resist for those who know
Old Nov 15, 2005 | 11:05 PM
sockvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">its a honda?</TD></TR></TABLE>
ha thats what i was thinkin at first
Old Nov 16, 2005 | 05:51 AM
SLO Sol's Avatar
95 dx with the b18c1 swap
97civic07gsxr
10
Apr 6, 2009 07:16 AM
ls19integra95
Sep 6, 2007 06:29 PM
B_Love
Jul 7, 2005 09:15 PM
Tchleung
Jan 25, 2005 12:06 PM
Doug684
Feb 17, 2004 02:07 PM
