how do you reset the ecu without clearing the radio too?
Old Nov 15, 2005 | 07:56 AM
gftgrill's Avatar
Default how do you reset the ecu without clearing the radio too?
ok, I want to know how to clear the codes from the ecu without pulling the backup fuse or removing the neg battery cable. I hate having to reprogram my radio.
thanks for any help.
edit:
if it makes a difference, it's a 99 ex.
Old Nov 15, 2005 | 07:58 AM
L8apex's Avatar
Default Re: how do you reset the ecu without clearing the radio too? (gftgrill)
OBD scan tool would be my first guess.
Old Nov 15, 2005 | 08:01 AM
Slow EJ8's Avatar
Isnt there a fuse for just the ECU? Not sure though.
Old Nov 15, 2005 | 08:13 AM
Relic1's Avatar
with a 99 you can do it with the scan tool (most parts stores will do it for you for free) or remove the ECU from the harness.
Old Nov 15, 2005 | 08:41 AM
nocturnaldragon's Avatar
There is an ecu fuse but I belive it also powers the radio backup, your best bet is to unplug it or get the obd2 tool and clear it.
Old Nov 15, 2005 | 08:52 AM
gftgrill's Avatar
yeah the backup fuse is labeled "backup radio fuse" or something similar. I don't have a scanner tool, and don't want to drive to a place to have them do it each time. so I guess I'll just unplug the ecu from the harness.
Old Nov 15, 2005 | 10:27 AM
snatch's Avatar
Default Re: (gftgrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill &raquo;</TD></TR><TR><TD CLASS="quote"> so I guess I'll just unplug the ecu from the harness.
This is what I always do. Just unplug the green plug from the ECU behind the passenger kick panel. Works just like unplugging the battery cable.
Old Nov 16, 2005 | 07:39 AM
gftgrill's Avatar
Default Re: (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">
This is what I always do. Just unplug the green plug from the ECU behind the passenger kick panel. Works just like unplugging the battery cable.</TD></TR></TABLE>
thank you, it worked. no more having to reset my radio.
Ithinkyourlost
Oct 23, 2007 10:35 AM
civiclxb16a
Dec 23, 2004 02:55 PM
citrusdrop
Nov 18, 2003 08:57 AM
zseeanz
Apr 1, 2003 06:54 PM
SoNNyBoY9o9
Nov 4, 2002 09:23 AM
