Will Integra gsr front and rear swaybars promote adequete "turn in "for and 92 Eg hatch???
If anyone has any advice as to weather the intregra gsr front and rear swaybar conversion will be sorry or pretty good for the amount of $$$ spent? I have done the front already and i was planing to do the rear, but a pal tells me that the small diameter of the rear sway will not promote adequete turn in and I should have got a skunk two or ground controll. please anyone out there who has experimented with this swap. please some feed back!!!!!
You should look into an ITR rear swaybar conversion.....
The USDM ITR rear bar is 22mm and is fairly easy to install. All you nedd are the GSR rear LCAs', ITR "SSO" D bracket and bushings, GSR endlinks, and a subframe brace such as this http://www.geocities.com/beaksproducts/main.html
This is definetly a good conversion to eliminate understeer and "promote adequate
turn in"...............
Edit- Nice Sig..........
[Modified by JV, 6:05 PM 3/11/2002]
spoonef
26
Jun 30, 2014 01:51 AM
Scotty Dosent Know
Suspension & Brakes
11
Sep 27, 2006 01:40 AM
SpoonSportsFanatic
Mar 14, 2002 11:07 AM
Pressurized
Nov 28, 2001 03:09 PM
