Is the Integra GSR rear sway bar good on a 92 civic hatchback?
Old Mar 11, 2002 | 12:26 PM
SpoonSportsFanatic's Avatar
Default Is the Integra GSR rear sway bar good on a 92 civic hatchback?
If anyone has any advice as to weather the intregra gsr front and rear swaybar conversion will be sorry or pretty good for the amount of $$$ spent? I have done the front already and i was planing to do the rear, but a pal tells me that the small diameter of the rear sway will not promote adequete turn in and I should have got a skunk two or ground controll. please anyone out there who has experimented with this swap. please some feed back!!!!!
Old Mar 11, 2002 | 03:41 PM
Katman's Avatar
Default Re: Is the Integra GSR rear sway bar good on a 92 civic hatchback? (92dxHatch4Jerry)
umm...
are you one of these?
Cuz, I'm jfwy ....
puttin GSR/ITR FR & RR swaybars on an EG is worth every penny (and it shouldn't cost too much either - used)..that is if you're into 'using your car'. What I mean by using your car, is really driving it ...like road racing or auto-x. Not drag racing. Swaybars dont do sh*t for dragging but add weight to your car.
ITR rear swaybar is cheap and way affordable, if you get all the right parts. You should look into the BEAKS kit for an EG. The ITR rear bar brand new from Acura is about $60-70. You'll need to use the endlinks from a GSR rear swaybar....so you could just transer the mounting parts over if you already have a GSR rear bar and mounting hardware.
Old Mar 13, 2002 | 11:38 AM
Beaks's Avatar
As Kat mentioned, I make a reinforcement kit for the ITR bar for your EG chassis. Go to the site for more info www.BeaksProducts.com. I can supply O.E. Acura/Honda parts as well.
-Wil
Old Mar 13, 2002 | 06:36 PM
InevitableRace's Avatar
Look at that ffsquad being an ******* like always just like those people at jdmhondaparts.com.are you people always like that?im never buying anything from you people again.and i talk people out of buying thing s from you people over here in florida..and it was over 20 people and half of them wanted motors.hahaha
Old Mar 14, 2002 | 08:25 AM
Katman's Avatar
Default Re: Is the Integra GSR rear sway bar good on a 92 civic hatchback? (allmotrb18c1)
hah sourpuss! Can't take a joke eh? i understand.
Old Mar 14, 2002 | 08:44 AM
JDMOption's Avatar
Default Re: Is the Integra GSR rear sway bar good on a 92 civic hatchback? (Katman)
ive never had a problem with jdmhondaparts or katman, if anything katman has helped me and many people out on the hybrid forum. b18c whats part of jacksonville are you in?
Old Mar 14, 2002 | 09:10 AM
Katman's Avatar
Default Re: Is the Integra GSR rear sway bar good on a 92 civic hatchback? (JDMOption)
heh, thanks. That's what I'm here for -- to help people. Some people just don't seem to see that
Old Mar 14, 2002 | 11:07 AM
ZXVIIR's Avatar
EEEEZZZZZZZZZZZZZZZ!!!!!!
Scotty Dosent Know
Suspension & Brakes
Aug 28, 2005 08:18 AM
JDMTurboCivic11
Jan 25, 2005 07:06 PM
typeeg
Sep 26, 2003 04:50 PM
killerboots
May 26, 2003 07:55 AM
gsrpilot8000
Aug 19, 2002 01:09 AM
