Spark plug question.
I have a 1999 civic hx. The oem ngk plugs are ZFR4F-11 v power. I went to kragen and they sold me some standard ngk v power plugs. The part number started with a brk or bkr I dont recall. Is that okay to use?
As long as they fit and are gapped properly, any spark plug will work. If you are asking because they didn't give you the V-power plugs, then yes you'll be fine.
Maybe NGK BKR4E-11 or BKR5E-11 or BKR6E-11
All of them are good and ARE FOR YOUR CAR...
BKR4E-11 is the plug with the same specs like ZFR4F-11
do not worry, if you have on of the mentioned plugs, you are safe
On your car you can use the following plugs:
BKR4E-11
BKR5E-11
BKR6E-11
ZFR4F-11
ZFR5F-11
ZFR6F-11
The number before E or F (BKR4E-11) can vary depending on your climate... hotter climates higher the number... colder climates, lower the number...
BKR4E-11
BKR5E-11
BKR6E-11
ZFR4F-11
ZFR5F-11
ZFR6F-11
