new clutch and grinding?
I had jus gone to the tracks about 3 weeks ago and my clutch just got destroyed. The disc was broken in 3 places. Something the mechanic said he had never seen. Anyways, i got the clutch changed and now that i shift into 3rd at about 3500rpm or higher it grinds. Why is this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbose axsassin »</TD></TR><TR><TD CLASS="quote">its not ur clutch, its ur synchros. replace the 3gear synchro.</TD></TR></TABLE>
Well, that's the worse case. It's not ALWAYS the synchros. It could be the linkage not aligning, the clutch (various bearings) not installed correctly, transmission fluid flush/replace/fill.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">
Well, that's the worse case. It's not ALWAYS the synchros. It could be the linkage not aligning, the clutch (various bearings) not installed correctly, transmission fluid flush/replace/fill.</TD></TR></TABLE>
dont always jump to the more severe problems...it could just be like what shamoo stated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbose axsassin »</TD></TR><TR><TD CLASS="quote">its not ur clutch, its ur synchros. replace the 3gear synchro.</TD></TR></TABLE>dont always jump to the more severe problems...it could just be like what shamoo stated.
Guest
Posts: n/a
well, it only grinds on third so that was my first guess. if it was anything else, wouldnt it have an effect on 1st, 2nd, 3rd, 4th, and 5th?
thats my guess.
and yeah, banned again. for no apparent reason.
thats my guess.
wen i redline and then shift to 2nd it will grind once in a while and that is not because i dont have have foot down on the clutch...it is down on the clutch...n e ways wut do u guys think is main problem and how much you guys think it would cost me
not alwasy the synchros could be the linkage is alligned right also if it is your syncros your better off replacing all of them with some carbon coated syncros and replacing all the bearings and seals if opeing it up http://www.gear-speed.com is a great website all about Honda/Acura transmission rebuilds. also better off getting a clutch master cylinder gets rid of those grinds plus you get better clutch response
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy2154 »</TD></TR><TR><TD CLASS="quote">how much is this all gonna cost me? i already dropped 500 on clutch</TD></TR></TABLE>
it might not be the tranny. was it grining before the clutch change?
no it wasnt grinding before the clutch was changed...thats the thing...but then again the clutch was so messed up that some parts cud have come out and damaged other things around it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggy2154 »</TD></TR><TR><TD CLASS="quote">no it wasnt grinding before the clutch was changed...thats the thing...but then again the clutch was so messed up that some parts cud have come out and damaged other things around it</TD></TR></TABLE>
check you bleeding on the clutch fluid, the clutch might not be dis-engaging all the way...iuno its possible, if something wasnt installed right.
meagainsttheworld
Aug 30, 2006 05:53 PM
90hatchie
Nov 10, 2004 12:04 PM
