can i weld this mount bracket to my frame? where can i get it, part number?
i have an 88 accord that i am droping a b series into. the only problem was with the tranny mount. my original tranny mount bracket was bolted on so i unbolted it and removed it. i am going to try to use the mount bracket(s) from the 96-00 civics. i guess its a 2 piece setup where there is one small part that is spot welded to the frame and then there is the metal c part that actually goes around the mount.
can i just weld the c part to my frame or am i better off using both pieces.
any1 have honda part numbers for these, my local junkyard never has this stuff
this is the original mount bracket from the da integra, i was going to drill out the stop welds and weld it in but i thought the civic mount would be esier
Modified by h0ndavtec at 1:17 AM 11/15/2005
h0ndavtec,
Just buy a new rightside frame rail mount from the dealer. IF you can get a used one off chances are it will be warped from the removal.. I have done this myself and it isn't worth the trouble to drill out the spotwelds on a piece that is $30 brand new.
the soL that could
Aug 21, 2011 07:08 AM
Mr. JDM-GSR
May 27, 2004 01:16 PM
