Who know the diffirence axia Civic Typ R and integ Typ R
Old Nov 14, 2005 | 11:01 AM
hondastreet's Avatar
Default Who know the diffirence axia Civic Typ R and integ Typ R
I buy a conversion Type R Set-up Brake 5 bolt for my CIVIC 2000 HB
Somebody, tell me that i need to change my axial
Why, and is-it true ?
Hugo
Actualy, I have in my car B-series transmission, SI set-up Brake
Old Nov 14, 2005 | 11:04 AM
Kendall's Avatar
The JDM 98 spec ITR 5 lug conversion uses a larger diameter spline than the US market 5 lug conversion and the CTR 5 lug conversion. If you have a 98 spec ITR 5 lug then you will indeed need different axles.
PS: Grammar > You
Old Nov 14, 2005 | 11:12 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Kendall)
At first I thought, hey its one of our foreign friends checking in from overseas some where. Then I saw that your from the US. Your grammar is pretty horrible.
Hopefully Kendall answered your question cause I have absolutely no clue what you are talking about!!!
Old Nov 14, 2005 | 11:25 AM
Sorry for my grammar, I'm french
YOu can confirm this information
Tread Civic Type R: 1480mm
Tread Civic SI : 1475mm
So, This is the reason why i need to change my axle, the tread is différent, so the axle are more longer then the ordinary civic
Spec type R
http://www.j-garage.com/honda/civic/97spec.htm
Spec SI:
http://odin.vl.ru/specs/1995.9/12303/
Hugo
Old Nov 14, 2005 | 11:28 AM
Oki, but about the longer ?
Old Nov 14, 2005 | 12:04 PM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for my grammar, I'm french
Spec type R
Spec SI:
Hugo</TD></TR></TABLE>
Your grammar is ten times better here.
What year ITR did the five lug conversion come off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">The JDM 98 spec ITR 5 lug conversion uses a larger diameter spline than the US market 5 lug conversion and the CTR 5 lug conversion. If you have a 98 spec ITR 5 lug then you will indeed need different axles.
PS: Grammar &gt; You</TD></TR></TABLE>
I thought it was the 96 axles that were different?
Old Nov 14, 2005 | 12:29 PM
Kendall's Avatar
Default Re: (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was the 96 axles that were different?</TD></TR></TABLE>
You are incorrect sir.
Old Nov 14, 2005 | 12:43 PM
cool guy name
So the 98 JDM ITR Five lug uses the 36mm?
I thought that the JDM 4 lug(96) used the 36mm and the rest were 32.
Thanks for the correction.
Old Nov 14, 2005 | 05:06 PM
mugenracer's Avatar
US/UK/Euro and JDM 96spec used a 32mm hub/axle, only JDM 98spec's have 36mm axles. EK9 also use 32mm axles.
Old Nov 15, 2005 | 07:47 AM
Default Re: (mugenracer)
oki, perfect !!!
So, I just need to verify if i have 36mm, I need to change my axle
If not, i will use my current axle.
Hugo
Old Nov 15, 2005 | 07:57 AM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">US/UK/Euro and JDM 96spec used a 32mm hub/axle, only JDM 98spec's have 36mm axles. EK9 also use 32mm axles.</TD></TR></TABLE>
Thanks for the lesson Kendall and mugenracer.
Old Nov 15, 2005 | 12:50 PM
which has lower control arms in tole folded: Civic or Integra ?
Old Nov 16, 2005 | 09:12 AM
cool guy name
Default Re: (hondastreet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondastreet &raquo;</TD></TR><TR><TD CLASS="quote">which has lower control arms in tole folded: Civic or Integra ?</TD></TR></TABLE>
wtf?
Old Nov 16, 2005 | 09:45 AM
eK9aT10pSi's Avatar
what do you mean folded?
Old Nov 16, 2005 | 10:34 AM
D's Avatar
D
Default Re: (eK9aT10pSi)
He's asking which LCA's are made of stamped/roll formed steel... versus the cast/forged pieces on DC2. however, he's already answered his own question above.
i'm getting so tole folded this weekend at We-Todd-X... jesus.
{edit} answered ? in other thread.
Paulie Pesos
Jan 24, 2010 06:10 PM
jdmxGod
Sep 1, 2005 12:51 PM
jdmxGod
Aug 17, 2005 01:25 PM
RhdRicheeee
Oct 19, 2004 05:16 AM
