Water Coolant - Drip drip drip..
I just replaced my coolant for the winter. I used Dexcool, if it matters.
Prior to replacement, I had no loss of coolant. All was fine. But now, (and it may not
be related), I get a slow, constant drip just by gasket for the oil pan, by the main pulley for the alt belt.. I suspect this is where the water pump resides ?
If so, is the water pump a major pain-in-the-donkey to replace/repair ?
1992 Honda Accord EX 4 door 2.2 Automatic A/C
Modified by tincan_1 at 10:02 AM 11/14/2005
Modified by tincan_1 at 10:09 AM 11/14/2005
Modified by tincan_1 at 1:14 PM 11/14/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda »</TD></TR><TR><TD CLASS="quote">on your on your on your... particular year and model it is not too bad</TD></TR></TABLE>
Put this info in your sig so you don't have to tell us every time you have a question
you have to remove the timing belt to replace the water pump . 90 and newer water pump is driven by the timing belt, if it is pre 90 you can replace water pump without removing timing belt, pump is on the outside of timing belt cover,
aarrggh.. that's compact engineering for ya. I'll re-check for loose hoses first.. I'm not up for a major dis-assembly just to reset/reseal a water pump gasket. Maybe I'll just strap on a catch bucket and it can swing freely underneath until its near full, empty back into rad, start over.
YUP, a Perfect chance to use that "Air Hook" you got for last Christmas. And just think, with the coolant you recover, you can make that bucket of steam you always wanted.
For GOD's sake ......... just fix it.
The way things work, you'll be out in East Bumf...k somewhere when the ^%$*& thing goes. Besides, this will give you the chance to replace that long overdue Timing belt at the same time.
Hey, What an Opportunity !!
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">YUP, a Perfect chance to use that "Air Hook" you got for last Christmas. And just think, with the coolant you recover, you can make that bucket of steam you always wanted.
P
Should have just let him figure that out
P
</TD></TR></TABLE>Should have just let him figure that out
heck i would construct a motorized pipe so i could recycle the coolant that leaks back in the radiator ,that way i would not have to stop,, and fill the radiator from time to time..Man i could just sit back relax listen to the radio mm nmm
1baddcivicsi
Apr 24, 2006 07:33 PM
