i have a 93 gsr: putting in a Pr3 obd 1 ecu.... but i have a problem...please READ!!!
Old Mar 11, 2002 | 09:00 AM
gokooljapan's Avatar
Default i have a 93 gsr: putting in a Pr3 obd 1 ecu.... but i have a problem...please READ!!!
first off i have a 1993 GSR integra which is an obd1.....(grey plug), OR IS IT????? i recently purchased a OBD1 pr3 ECU(from japan)......the problem is that i have a couple of codes which are code 41 and code 20.......i think the reason that i am throwing the codes are that i need a 4 wire O2 sensor....my car came with a 1 wire O2 sensor...but i dont understand since my car SHOULD be a OBd1??????
has anyone experienced this problem? please help...or if anyone has wired up a 4 wire O2....i know of people putting in p28's in a crx or a NON obd car using a jumper harness....so i am sure it is possible....please help...thanks
Old Mar 11, 2002 | 10:23 AM
GM2000ITR's Avatar
New User
Default Re: i have a 93 gsr: putting in a Pr3 obd 1 ecu.... but i have a problem...please READ!!! (gokooljap
1. Your car IS OBD1. , 2. Remember that a PR3 ECU will have a speed limiter stock . , 3. I don't really remember about the O2 sensors Good Luck!
SlowB20z
May 24, 2013 06:02 AM
ef-hatchcrap
Jul 30, 2009 02:32 PM
absolut b18
Aug 26, 2003 02:27 PM
gokooljapan
Mar 14, 2002 06:13 PM
