Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
DC2 Integra front sway bar options?
Old Nov 14, 2005 | 07:30 AM
SPiFF's Avatar
Default DC2 Integra front sway bar options?
I ran with the front bar off the 1st half of the ARRC weekend and I really didn't like it at all. With the stock front bar on, the car felt better for me, but there is noticeably less front end bite.
AFIAK, the GSR has a 24mm front bar. What are my options for a smaller bar?
Thanks ....
Old Nov 14, 2005 | 07:34 AM
.RJ's Avatar
.RJ
Default Re: DC2 Integra front sway bar options? (SPiFF)
RS/LS = 21mm, thats what I've got on the car now, with the 32mm rear.
Old Nov 14, 2005 | 07:45 AM
Honda318dx's Avatar
Default Re: DC2 Integra front sway bar options? (.RJ)
spring rates? you should be stiff enough to realize its not there when you take it off..
Old Nov 14, 2005 | 07:48 AM
SPiFF's Avatar
Default Re: DC2 Integra front sway bar options? (Honda318dx)
800/1200. Stock front bar, 26mm rear.
Old Nov 14, 2005 | 07:53 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">spring rates? you should be stiff enough to realize its not there when you take it off..</TD></TR></TABLE>
With 800/1000 on my car I really noticed that it was gone when I disconnected it. I also had the small (22mm) rear bar on - but without the front bar there just wasnt enough front roll stiffness to keep the car off the bumpstops on the bumpy bits of summit. Its back on, with the 32mm rear bar, 850# f, 700# rears.
Old Nov 14, 2005 | 08:04 AM
Honda318dx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
With 800/1000 on my car I really noticed that it was gone when I disconnected it. I also had the small (22mm) rear bar on - but without the front bar there just wasnt enough front roll stiffness to keep the car off the bumpstops on the bumpy bits of summit. Its back on, with the 32mm rear bar.</TD></TR></TABLE>
Hum.. I do have that issue as well, but its not an easy fix. If I put the front bar on, it will make that inner tire spin more..
Damnit, I'll just buy a Kaaz someday..
Old Nov 14, 2005 | 08:07 AM
Kaan's Avatar
Loved
Community Favorite
Damnit, I'll just buy a Kaaz someday..</TD></TR></TABLE>
why? you are selling the tank... *shakes head*
Old Nov 14, 2005 | 08:32 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPiFF &raquo;</TD></TR><TR><TD CLASS="quote"> What are my options for a smaller bar?</TD></TR></TABLE>
aside from the LS bar RJ mentioned, you can use the 92-95 Civic front bar.. I have this with my 12k/8k and Whiteline Adjustable rear bar on it.. I like it so far.. I ran without a front bar at all for awhile with the OEM rear and I didn't care for that as much..
Old Nov 14, 2005 | 12:36 PM
solo-x's Avatar
Default Re: DC2 Integra front sway bar options? (mstewar)
nebermind, learned something new.
Modified by solo-x at 10:56 AM 11/15/2005
Old Nov 14, 2005 | 03:18 PM
BlueTeg's Avatar
Default Re: DC2 Integra front sway bar options? (solo-x)
RS/LS = 22mm
92-95 Civic EX/Si front bar = 21mm
[shameless plug]I've got a 22mm LS front swaybar I'm looking to sell.
Old Nov 14, 2005 | 03:21 PM
.RJ's Avatar
.RJ
Default Re: DC2 Integra front sway bar options? (BlueTeg)
The RS/LS is a 21mm
Old Nov 14, 2005 | 07:00 PM
philstireservice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">RS/LS = 21mm, thats what I've got on the car now, with the 32mm rear.</TD></TR></TABLE>
Yep, what RJ said......21mm on my car too....
Old Nov 15, 2005 | 09:27 AM
White98LS's Avatar
Really? I've always seen 22.1mm as the spec on it. I'm pretty sure it actually says that in my Integra brochure.
Old Nov 15, 2005 | 09:31 AM
BlueTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The RS/LS is a 21mm</TD></TR></TABLE>
LS/RS is 22mm (Honda part # 51300-SR3-N02)
See here:
http://www.acuraparts247.com/p...ch=no
Technically the LS came with either the 22mm front swaybar or 24mm front swaybar, depending on which year LS you're talking about. Beginning in '99, Honda started outfitting the LS with the 24mm front swaybar (Honda part # 51300-ST7-003, same as the GSR/ITR).
See here:
92-95 Civic Si and EX (I can't remember if the LX received one or not) had the 21mm front swaybar.
Old Nov 15, 2005 | 09:34 AM
Jimmy L's Avatar
Default Re: DC2 Integra front sway bar options? (White98LS)
I just got an LS bar and it is awaiting install. How do you guys like it over the GSR or no bar?
Other than the LS, King sells the 18mm Mugen bar but it's $300.
Old Nov 15, 2005 | 09:36 AM
.RJ's Avatar
.RJ
Well I had no idea.
Time to get my hands on one of them 21mm bars....
Old Nov 15, 2005 | 09:44 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">
ding ding ding.. winnAr!
AFAIK, the LX and DX did not get the front bar.. Si and EX only..
Old Nov 16, 2005 | 05:59 AM
[QUOTE
[/QUOTE]
That's the bar I have in my car....
Old Nov 20, 2005 | 08:53 PM
SPiFF's Avatar
Thanks for the good info guys!
I am now on the hunt for a 21mm Civic bar.
Old Nov 20, 2005 | 10:59 PM
RTI's Avatar
RTI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">LS/RS is 22mm (Honda part # 51300-SR3-N02)
See here:
See here:
92-95 Civic Si and EX (I can't remember if the LX received one or not) had the 21mm front swaybar.</TD></TR></TABLE>
I can confirm that a 98 LS came with a 22mm front bar. Measured it with a caliper.
MrXclusivE
Suspension & Brakes
Apr 17, 2008 06:53 AM
RyanA
11
Jan 20, 2008 10:04 PM
Merlin8188
Sep 27, 2005 10:57 PM
TegoDC5
Suspension & Brakes
14
Sep 13, 2005 08:45 AM
B18ek
26
Jun 7, 2005 12:45 PM
