transmisson question
Old Nov 13, 2005 | 08:43 PM
hinds90's Avatar
Default transmisson question
I am trying to buy a teg this week and it has shifting problems. When you try to put it in gear above 3500 4000 rpms it dosen't want to go but after it idles down a bit it will go. My question is could it be the slave cylinder or the syncros and wht would be your estimate on repair. Thanks for any help.
Old Nov 13, 2005 | 09:09 PM
blkb18's Avatar
Default Re: transmisson question (hinds90)
if it grinds going into gear its most likely syncros, unless the linkage is bent but thats unlikely. If you need a slave cylinder the clutch pedal most likely wont come up off the floor. Slave cylinder is a real cheap fix, syncros can get expensive, maybe $1000-1200 job (dealer prices), but thats a guess.
Old Nov 13, 2005 | 09:45 PM
hinds90's Avatar
Default Re: transmisson question (blkb18)
Yeah the clutch pedal comes up off the floor good. When I drove it I hit it in second and it grind when I put it in third. what would I look for if it was the slave cylinder.
Modified by hinds90 at 11:29 AM 11/14/2005
Old Nov 14, 2005 | 08:30 AM
hinds90's Avatar
bump
Old Nov 14, 2005 | 02:46 PM
shamoo's Avatar
Will you make something up for me please?
It won't be any of your cylinders, by the symptoms you are describing. If they were failing, then you would be leaking fluid and the clutch wouldn't fully disengage, and sometimes the pedal would stay on the ground.
When you try to force it in gear, it grinds, right? Does it only do it in 3rd gear? I'm asking because Honda transmissions unfortunately suffer from an early 3rd gear synchros retirement.
Unless you can service it yourself, like the other poster said, it will/can quite expensive to repair.
Have you tried the easy stuff first, such as checking/replacing/flushing your transmission fluid? There are many aftermarket fluids that are very good and sometimes "repair" the grinds.
Old Nov 14, 2005 | 02:49 PM
italionstallion888's Avatar
Default Re: transmisson question (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">It won't be any of your cylinders, by the symptoms you are describing. If they were failing, then you would be leaking fluid and the clutch wouldn't fully disengage, and sometimes the pedal would stay on the ground.
Have you tried the easy stuff first, such as checking/replacing/flushing your transmission fluid? There are many aftermarket fluids that are very good and sometimes "repair" the grinds.</TD></TR></TABLE>
check out GM synchromesh, I havn't used it yet, but a buddy of mine put it in his DA and it shifts fine now.
Old Nov 14, 2005 | 08:07 PM
hinds90's Avatar
Default Re: transmisson question (italionstallion888)
I think you are right . When i was driving it I gave it some gas in second and when I shift in to third it grind so I don't know about the other gears I will have to drive it again .
Old Nov 14, 2005 | 08:12 PM
hinds90's Avatar
These are the specs on the car
95 Gsr ( I think teal green or some really faded green)
209,xxx mL
broken passenger head light
missing passenger side molding (quarter panel)
other little stuff missing on the inside of car nothing big
The body it self is in pretty good condition
as far as the motor its dirty as hell but it runs pretty good
He wants 2,800 for the car do you guys think its worth it
Old Nov 14, 2005 | 08:14 PM
Vtecme92's Avatar
easiest way out, buy the car for a good price, sell that tranny and get yourself a new one! you can easily sell that one for $300 bucks with the grind or maybe even more and upgrade to better tranny...or you can try to fix it yourself which will be more headaches...drop that tranny out and drop in a new one...
Old Nov 14, 2005 | 08:24 PM
hinds90's Avatar
Default Re: transmisson question (Vtecme92)
I was already planning on buying a new motor for the carand trying to get it painted but if the tranny is bad that throws a big wrench in my plans because a gsr from hmotoronline is 700 .
But do you guys think the car is worth 2,800 with the mileage and maybe a bad tranny.
Old Nov 14, 2005 | 08:29 PM
JDMtype Eg6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by italionstallion888 &raquo;</TD></TR><TR><TD CLASS="quote">
check out GM synchromesh, I havn't used it yet, but a buddy of mine put it in his DA and it shifts fine now.</TD></TR></TABLE>
you can use the gm synchromesh as an alternative especially if your budget is tight. it can also buy u some time so you can rebuild or change the tranny. Ive been running gm synchromesh for about 4 months and my grinds magically disappeared after about 3 weeks.
Old Nov 14, 2005 | 09:39 PM
hinds90's Avatar
Default Re: transmisson question (JDMtype Eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote">These are the specs on the car
209,xxx mL
He wants 2,800 for the car do you guys think its worth it</TD></TR></TABLE>
kevinm1981
10
Nov 8, 2010 05:27 AM
lo0nY
Feb 26, 2006 03:58 PM
johnqt3
Oct 7, 2005 11:05 AM
Monkeyballs
Feb 1, 2004 09:28 PM
JDM_CD7
Apr 12, 2003 02:07 AM
