My Tig welds....
whats up guys, this is my 4th time Tig welding and I think they came out pretty good, I was using a DYNASTY 300 with the watercooler, I cant remeber which rod. this is mild steel.
tell me what you think...
I have a nervous hand somtimes ^
-Jon
-Jon
You have good mechanics down, now all you do from there is practice and get better. Be carefull on the heat on the t weld. I know its hard to keep the puddle goin sometimes, but i can see a little bit of undercutting. Just add more filler and you'll be set.
doing a bead on a flat piece of metal is not too bad, now try to but weld two pieces tougheter and see how it works.
btw: u want to start with some thinger materials so you get the idea on how to regulate your heat.
