question about tires and rims...
Old Nov 12, 2005 | 07:18 PM
cilvia's Avatar
Default question about tires and rims...
ok...selling my racing hart type c rims because its too wide for my car...the size is 17x7.5 and rubs like heck...the tires on them are 205/40ZR/17...now i got some racing hart c2 evo that i bought from someone which are 17x7 and has some 215/40/17 tires mounted on them...my first question is, whats the difference between the numbers 205 and 215?? are 215s wider or bigger?? will those make me rub still cause im lowered with a 2 finger gap all around...also, since my 205/40ZR/17 tires are mounted on my 7.5" wide type c rims, will it be less wide if i mount them on my c2s which are 7" wide?? thanks
Old Nov 12, 2005 | 08:55 PM
cilvia's Avatar
Default Re: question about tires and rims... (cilvia)
ok i just read this about tire size http://www.tirerack.com/tires/...id=46 ...soo 205/215 is the width of the tires...soo if i put 205 tires on my 7.5 inch wide rims, will the width of the tires expand or will it be the same width as if i put it on 7 inch wide tires??
Old Nov 12, 2005 | 11:20 PM
nsxtasy's Avatar
H-T Order of Merit
The width will be the same, because it's the width of the tread.
Old Nov 12, 2005 | 11:52 PM
cilvia's Avatar
Default Re: question about tires and rims... (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The width will be the same, because it's the width of the tread.
so the whats the difference between having 17x7.5 rims with 205/40/17 tires and having 17x7 rims with 205/40/17 tires?? soo if im rubbing with my 17x7.5 rims wit 205 tires, im going to rub the same with my 17x7 rims with 205 tires?? is that right then??
Old Nov 13, 2005 | 05:07 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">so the whats the difference between having 17x7.5 rims with 205/40/17 tires and having 17x7 rims with 205/40/17 tires??</TD></TR></TABLE>
1/2 inch difference in wheel width.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">if im rubbing with my 17x7.5 rims wit 205 tires, im going to rub the same with my 17x7 rims with 205 tires?? is that right then??</TD></TR></TABLE>
Yes.
And there aren't a whole lot of smaller size tires in 17".
Depending on how and where they're rubbing, it's possible that the offset on your wheels is wrong, in which case you can use spacers to move them out, but you can't really move them in. Also, rolling your fenders might help. And you could try returning your ride height to stock. Otherwise, you'll need to get smaller wheels with smaller tires.
Modified by nsxtasy at 1:24 PM 11/13/2005
Old Nov 13, 2005 | 09:12 AM
cilvia's Avatar
^^^soo what tire size should i get?? i thought people said 17x7 rims for a civic is the size people recommend to get with 205/40/17 tires...
Old Nov 13, 2005 | 10:26 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cilvia &raquo;</TD></TR><TR><TD CLASS="quote">^^^soo what tire size should i get?? i thought people said 17x7 rims for a civic is the size people recommend to get with 205/40/17 tires...</TD></TR></TABLE>
That's the smallest size you can get for 17" wheels, even though the outer diameter is still significantly bigger than stock. You can't just switch to a smaller tire size on those wheels.
You'll have to try some or all of the things I mentioned above, to see whether any of them eliminate your rubbing problems. Otherwise, you'll have to get smaller wheels with smaller tires.
CRuNCHyEM1
Dec 19, 2010 11:37 AM
JDM Accord 510
Dec 3, 2006 06:13 PM
volcom1887
Honda Civic (2001 - 2005)
Nov 30, 2006 09:04 AM
crazy_ham
Jan 22, 2003 06:59 PM
