need a little help... finding a part
Old Nov 12, 2005 | 05:55 PM
david
Guest
Posts: n/a
Default need a little help... finding a part
Oxygen Sensor Heater (Secondary)
malfunctioning or defective oxygen sensor heater
car is a automatic 2000 accord Lx sedan. anybody know where that's located at? this is the code i got. 67
Old Nov 12, 2005 | 06:13 PM
BLKFLSH's Avatar
Default Re: need a little help... finding a part (david)
It is located on the exhaust piping. follow down from manifold toward the catilytic converter. I don't know if there is one or two on that model, lx usually has just one.
Old Nov 12, 2005 | 06:15 PM
david
Guest
Posts: n/a
Default Re: need a little help... finding a part (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">It is located on the exhaust piping. follow down from manifold toward the catilytic converter. I don't know if there is one or two on that model, lx usually has just one.</TD></TR></TABLE>
so there are 2 oxygen sensors?
Old Nov 12, 2005 | 06:22 PM
BLKFLSH's Avatar
Of course there are. Did you doubt it? Look on the exhaust I guarantee you will find at least one.
Old Nov 12, 2005 | 06:24 PM
david
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">Of course there are. Did you doubt it?</TD></TR></TABLE>
sorry.... i meant there are 2... the primary... and a secondary?
Old Nov 12, 2005 | 06:26 PM
BLKFLSH's Avatar
There may be two, I'm not sure about your year. You would have to get under there and check it out. Unless you have a repair manual. Which, by the way is a good idea. Get one. Preferably helm (it's the one factory techs use)
Old Nov 12, 2005 | 06:30 PM
BLKFLSH's Avatar
If you look it up on one of the on-line parts stores it might say secondary and primary, or something to that effect.
Old Nov 12, 2005 | 06:32 PM
P_Adams's Avatar
The 2000 Accord is equipped with an OBD2 Engine Management system (first seen in the 5th Gen Accords). It requires two O2 sensors. A primary one ahead of the converter, and one behind. The O2 Sensor heater is incorporated in the sensor itself, and is traditionally found in the second (#2) sensor position. It can be recognized by three wires that run to it. Two for the sensor operation, and the third for the heater.
If it set a hard code, you'll have to replace it.
P
Old Nov 12, 2005 | 06:35 PM
BLKFLSH's Avatar
Default Re: need a little help... finding a part (P_Adams)
Old Nov 12, 2005 | 06:39 PM
david
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">The 2000 Accord is equipped with an OBD2 Engine Management system (first seen in the 5th Gen Accords). It requires two O2 sensors. A primary one ahead of the converter, and one behind. The O2 Sensor heater is incorporated in the sensor itself, and is traditionally found in the second (#2) sensor position. It can be recognized by three wires that run to it. Two for the sensor operation, and the third for the heater.
P</TD></TR></TABLE>
so what you're saying is there are '2' sensors.. one behind the cat and one before it. because that is what i see... and im getting code 67.
Old Nov 12, 2005 | 06:44 PM
BLKFLSH's Avatar
I think that's what the man said, and he is an expert. I'm not.
Old Nov 12, 2005 | 06:48 PM
P_Adams's Avatar
Yes, in every language I can think of........
P
Old Nov 12, 2005 | 07:00 PM
david
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Yes, in every language I can think of........
P</TD></TR></TABLE>
cool thanks... i needa go buy that part.
Em1Doode
Honda S2000
12
Oct 15, 2008 08:07 AM
dorkjoey
May 8, 2008 03:07 PM
NA-C5
Sep 2, 2007 08:56 PM
-iLLuZioN-B18C1
Dec 12, 2005 11:40 PM
d98clturbo
Aug 23, 2003 12:47 PM
