convert wire obdo to obd1?
i have been searching and have not find the answer i wanted. there has been alot of obdo to obd1 with the obd1 dizzy but not wiht the obdo rewire to obd1. my buddy is asking if is possible to convert a obdo dizzy to obd1 without him buying a obd1 dizzy? he is convert his 91 teg b16a1 to obd1. he has everything but running low on cash and w/o the dizzy.
here is a link is a OBD0 to OBD1 convertion harnes , youll need that and an OBD1 ECU to convert your car
http://cgi.ebay.com/ebaymotors...ZWDVW
^ they have harnesses like what was posted.
i swaped my 91 rs to obd1 during a shell swap i was doing by swaping all my harnesses(engine, engine bay, and chassis/interior) from my 93 ls.
hes got that harness but wanted to see if he could use the obdo dissy instead of buying a obd1 dissy and the harness. or is there a way he could just rewire the obdo dissy to work with the obd1 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec90 »</TD></TR><TR><TD CLASS="quote">hes got that harness but wanted to see if he could use the obdo dissy instead of buying a obd1 dissy and the harness. or is there a way he could just rewire the obdo dissy to work with the obd1 ecu.</TD></TR></TABLE>
i believe that harness enables you to run obd0 wiring with a obd1 ecu.
Modified by projectTeG at 5:02 PM 11/21/2005
if he has the conversion harness then you should be able to use the existing obd0 wiring.
thats why they created them...so you could convert a obd2 car to obd1 with just a obd1 ecu....so on and so forth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">you will need to use an OBD1 distributor; obd0 wont work.
Pulses are different.</TD></TR></TABLE>
so then whats the point of the wiring harness if you still have to buy and wire up obd1 componets?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">so then whats the point of the wiring harness if you still have to buy and wire up obd1 componets?</TD></TR></TABLE>
the point of the adapter harness is to be able to use a obd1 ecu on an obd0 harness.
plugs and locations are different.
The point of the harness is to make everything plug and play so the ECU, dizzy and motor all work like they are suppossed to together. W/O the harness you would have to splice everything and that would suck, the OBDO parts themselves (ECU,dizzy) just won't work by "rewiring" since they work differently than OBD1 anyway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG »</TD></TR><TR><TD CLASS="quote">well i know that....i was asking because "mmuller" said that he was going to have to use the obd1 dizzy on the car.</TD></TR></TABLE>
you will have to use an obd1/2 dizzy; the obd0 will not work right.
you will have to use an obd1/2 dizzy; the obd0 will not work right. </TD></TR></TABLE>
oh ok ok...i see where your going with it. you would have to used a different dizzy if you converted a 0bd2 car to obd1 because the dizzy work similar. i thought from what you said you have to change the dizzy to the corresponding ecu
