Hasport Shift Linkage needed for b-series swap?
I have a 1997 honda civic hatchback. (manual) and am doing a b18c1 engine swap. i am gonna order the complete swap from hmotorsonline.com. do i need this: http://hasport.com/catalog/pro...id=53? or wil the stock linkage work ok. or the linkage from the donor car?
nah dude that **** is a rip off i found that out myself...its 150.00 plus shipping...any b-series linkage will work fine 94 up gsr or 99-00 civic si..i got mine from honda "new" oem for 89.00 lol i suggest you do the same its cheap as hell. ..i saved the part numbers just incase (1) 54301-s04-g10 (2) 54201-s04-g10 you need the both of them or if you forget just ask for shift linkage for a 99-00 civic si
iput a b18 in my crx and needed Has port linkage I would imagine your hatch woluld be the be the same. I don't think your hatch was available with a b series engine. 3rx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROKENB2O »</TD></TR><TR><TD CLASS="quote">nah dude that **** is a rip off i found that out myself...its 150.00 plus shipping...any b-series linkage will work fine 94 up gsr or 99-00 civic si..i got mine from honda "new" oem for 89.00 lol i suggest you do the same its cheap as hell. ..i saved the part numbers just incase (1) 54301-s04-g10 (2) 54201-s04-g10 you need the both of them or if you forget just ask for shift linkage for a 99-00 civic si</TD></TR></TABLE>
Yes I agree 100%
you can buy my Integra shift linkage $75 shipped. It will work with your set-up.
Yes I agree 100%
Note of caution - I had a problem running an Integra linkage in a 2000 civic with a B16A2 swap, and had to buy new Civic Si linkage. The problem was that the integra linkage was not bent in the same place the Si linkage was, and the linkage was constantly hitting against the secondary o2 sensor.
Not sure if this is a common issue, or maybe the used Integra linkage I bought was bent from an accident or something, but just a heads up. Stock linkage is only like $70 + tax + shipping from slhondaparts.com, so charging $150 (twice as much as the stealership!!!) is a ripoff either way you look at it.
92CIVICCX
Sep 13, 2003 01:13 PM
