Any SolidWorks experts in here???
Old Nov 12, 2005 | 02:51 PM
_BEN_'s Avatar
Default Any SolidWorks experts in here???
Hi,
I have been playing around with this program for a few days now. And have been trying to make a "tube elbow". Like an elbow that would be found in a cold air intake.
Whenever I try I usually end up with a funnel/velocity stack/ or some other weird shape with an open end.
Do I have to make a tube and bend it some how with the program, make 2 tubes and connect them some how, or is there a way I can program multiple pivot points for when I create the part in 3d.
Thanks.
SolidWorks is incredibly easy to use.
Here are some plans I made for my trucks rear windows. They will be replacing broken plastic pieces that are about .5" long. Nothing spectacular. But pretty good I guess for no training or experience.
Old Nov 12, 2005 | 03:06 PM
Goullish's Avatar
Default Re: Any SolidWorks experts in here??? (_BEN_)
I'm not sure if I understand exactly what you need, so check the pictures at the bottom of the post
SolidEdge v.17 directions (probably close, never used Works)
1. Sketch 1 line, the another at the preferred bent angle (I chose 90 for ease) at endpoint of line 1.
2. Use the fillet/radius tool to set the bend on the line to prefered radius. Finish, Finish.
3. New sketch, on "Plane normal to curve" at either end. Draw you tube profile [OD, ID]. Finish.
4. Swept Protrustion. Select your centerline, then your OD.
5. Swept Cutout. Select your centerline, then your ID. Viola.
http://www.we-todd-did-racing....x.jpg
Old Nov 12, 2005 | 04:19 PM
_BEN_'s Avatar
Default Re: Any SolidWorks experts in here??? (Goullish)
Thanks Ill give that shot.
Old Nov 13, 2005 | 09:18 PM
Lamchop0000's Avatar
open new drawing.
select front or right plane.
and open a sketch on it.
sketch an arc. with one of the circle or arc tools
close sketch.
select top plane
sketch a circle at the end point of the arc you made earlier.
close sketch.
select 'sweep boss/base'
select the first box in the left, then click on the circle
then click on the 2nd box and click on the arc
it should show a preview of what it would be.
then click on thin feature on the left and select the thickness.
hope that helps.
Old Nov 14, 2005 | 07:30 AM
beepy's Avatar
Or you could just make a single sketch with a circle and a centerline at the radius you are going for, and do a revolve. KISS.
Old Nov 14, 2005 | 08:22 AM
wreckedrex's Avatar
Default Re: Any SolidWorks experts in here??? (beepy)
True, but if you want to do something more like this:
then a swept feature makes more sense.
Dan
Edit: I'm not sure what version you've got, but the tutorials are actually really good for this kind of thing in 2004/2005 (not sure about other releases). They go through feature creation step by step.
Old Nov 14, 2005 | 03:37 PM
extremepowerperformance's Avatar
Default Re: Any SolidWorks experts in here??? (wreckedrex)
where do I get this program??? Is it free or do I have to purchase it???
thanks guys,
Gabriel
Old Nov 14, 2005 | 03:41 PM
I found this for $79
SolidWorks Student Edition 2005-2006
I am looking for something to do intercooler piping, exhausts, manifolds, etc...
thanks,
Gabriel
Old Nov 14, 2005 | 08:54 PM
_BEN_'s Avatar
Default Re: Any SolidWorks experts in here??? (LamRacing)
Thanks that did the trick.
It took me a few minutes to figure out what I was doing wrong. I kept tring to use the "revolved boss/base feature" when I should have been using the "Swept boss/base' like you mentioned.
MadtownSi
Welding / Fabrication
24
Dec 20, 2006 06:42 PM
racer_X_123
25
Oct 26, 2005 03:22 PM
vactor
Jun 11, 2003 07:10 PM
Sukebei Oni
Oct 24, 2002 09:43 AM
