whats your take on koni coilovers ?
koni yellows are among the best shocks you can get. These are those, with threads, and spings, so yeah... they're great
what makes koni yellows so good is that they are adjustable for compression and rebound and are fully rebuildable
my one question about them would be what the spring rate is, but it's probably well matched to the dampers, but worst case senario you could always get springs to your spec from ground control and put them on these threaded shock bodies.
[Modified by Rezon, 3:03 PM 3/11/2002]
external double adjustables are available through Truechoice, http://www.truchoice.com. Track use only.
96 SOHC VTEC
24
Jan 27, 2002 07:56 PM
