anyone use Eibach Pro Kit on there GSR
Old Mar 10, 2002 | 09:35 PM
cam003's Avatar
Default anyone use Eibach Pro Kit on there GSR
just wondered what my car is gonna handle and ride with the pro kit if you have any sugestions please feel free, andpost pix if you got em.
thanks
Old Mar 10, 2002 | 10:04 PM
MintyDip's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (cam003)
I use the Pro kit with Koni yellows. Handles Really well!!!!
I dont know how they will do with stock shocks tho, i have heard that they are a little too stiff for the stock shocks.
If i were u, get some shocks to complete the suspnesion, and when u can get the itr 22mm sway with a reinforcement kit. I use it with bsq kits
Here are som pix
Old Mar 10, 2002 | 10:10 PM
narisc's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (MintyDip)
nice ride.... is thats a 1.5" drop?
Old Mar 10, 2002 | 10:11 PM
Scary1109's Avatar
nice ride, looks pretty sweet
cam003's Avatar
thanx MintyDip your ride sits really nice i cant wait to get mine, and i am getting TOTIKO llumina shocks, thanx again
[Modified by cam003, 7:13 AM 3/11/2002]
Old Mar 10, 2002 | 10:36 PM
ndustryalGSR's Avatar
I've been riding on the Pro-kits for a few years now. Currently, I have them paired with some KYB AGX's. I like the combo quite a bit.
I used my stock shocks for a couple of years with the Pro-kits. It wasn't too bad. After a while, though, the lower spring took its toll on the stockers.
Old Mar 10, 2002 | 10:44 PM
araknis's Avatar
New User
Default Re: anyone use Eibach Pro Kit on there GSR (ndustryalGSR)
it's actually only a 1.3" drop. I have the same setup on mine except I'm using the KYBs.. mine seems a little higher though. oh well..
Old Mar 10, 2002 | 10:54 PM
PolySquared's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (araknis)
Hey mintydip, what kind of tires are you running (size also)?
Old Mar 10, 2002 | 11:41 PM
DrewGSR's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (PolySquared)
his car looks a little lower then 1.3 in. keep in mind that he is using koni yellows, so he can change his perch setting to make the drop even lower. I have the exact same setup and i really like them and that about the same drop as me, i have a 2 finger gap.
Old Mar 11, 2002 | 12:33 AM
MintyDip's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (DrewGSR)
yup
keep that in mine guys.
Eibach says their por kit gives 1.3-1.5 drop, koni yellows also have adjustable perch setting
i say my drop is a little lower then 1.5
My koni has 2 fron perch setting and 3 rear
my front is set at top and rear at center
also my tires are bridgestone potenza re730,
my opinion they grip real well,last real long and look sweeet. size 205-50-15
Old Mar 11, 2002 | 01:05 AM
vteg's Avatar
New User
Your drop looks the same as my sportlines.
Old Mar 11, 2002 | 05:20 AM
Got-VTEC's Avatar
New User
I just ordered a set of KYB AGX's paired with the Eibach Pro-Kit. Can't wait to get rid of my current set-up, GC/Blown Tokico's.
My car is pretty low now considering the shocks have nothing left in them and I know the Pro-Kit/AGX set-up will be no where near as low so I guess I will have to get used to the new set-up.
Old Mar 11, 2002 | 06:01 AM
quikB18B's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (Got-VTEC)
Minty Dip nice ride but if your car is set on the lowest perch with the koni's, you should let this guy know in case he cant afford the koni's just yet and thinks the pro kit will look like your setup.
Just wondering becauseyour setup looks almost identical to my sportline w/stock shock setup. Let us know
Old Mar 11, 2002 | 08:40 AM
MintyDip's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (quikb20)
like i said, my shocks are set at top perch front and center rear
it is so called "normal" height perch. But honestly it sits a little lower then normal.
cam003- my dropp is a little lower with my shocks. If you were to put pro kit springs on your stock shocks, expect a 1.3-1.5 drop. What you see in the pic i estimate a 1.8 drop becuase of my shocks.
Hope that helps
[Modified by MintyDip, 9:41 AM 3/11/2002]
Old Mar 11, 2002 | 09:12 AM
JMX's Avatar
JMX
those pics arent working, i would like to see what an integra looks like on a pro kit
and what about yoru camber problems, any un-even wear
Old Mar 11, 2002 | 09:19 AM
LS_racer's Avatar
Default Re: anyone use Eibach Pro Kit on there GSR (jmx2323)
I dropped my LS on a set Tokico's (not illuminas) and the Prokit. I ended up with camber that was way out. I have the slip somewhere which I can post if need be so I ended up getting a progress camber kit to fix it. of course I also drove from NY to OR like 3 days after I dropped it with a full car load so that might have contributed to the f'ed camber numbers.
defroza
Mar 23, 2006 04:41 PM
1337 Si
Apr 11, 2004 07:08 AM
fastfu
Dec 12, 2003 02:14 PM
LudeAchris2001
Aug 19, 2003 10:18 PM
ITR41
Sep 16, 2002 08:41 PM
