itr turbo
Old Nov 12, 2005 | 11:00 AM
tvman's Avatar
Default itr turbo
search thing is down...so anyone running itr turbo? how much whp you pushing and how much torque?
Old Nov 12, 2005 | 12:19 PM
ZygSpeed's Avatar
Default Re: itr turbo (tvman)
How much do you want to spend?
I hear some of the drag guys are getting ~800-1000 hp out of a B-series motor.
Old Nov 12, 2005 | 12:29 PM
R59's Avatar
R59
Default Re: itr turbo (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">How much do you want to spend?</TD></TR></TABLE>
Exactly..I'm looking at about 20k after all is said and done. I will be able to tune well over 600hp ..This is with a complete engine swap..
Old Nov 12, 2005 | 12:43 PM
Black R's Avatar
25 Year Member
stock motor ~300whp/ ~200 lb-ft tq
Old Nov 12, 2005 | 12:53 PM
AntiStock's Avatar
- Golden Eagle sleeved block, bored to 83mm, balanced and blueprinted bottom end 1.9L. Copper o-ringed combustion chambers
- Arias Pistons, 9.5:1 compression ratio
- Eagle connecting rods
- New stock type R valves
- Jun Cam Gears, dual valve springs
- Cometic Head gasket, .010" thicker than stock
- Golden eagle fuel rail and oil distribution block
- Precision T3/T4 turbo with 70AR and 60 series trim
- South Florida Performance Tubular Turbo Manifold
- HKS wastegate
- Greddy Type S blow off valve
- Greddy front mount intercooler
- Thermal 3" exhaust
- Precision 780 CC/min fuel injectors
AEM fuel pressure regulator and fuel filter
- MSD ignition and blaster coil
Previous owner dyno'd at ~370whp on low boost (14psi) and 430whp on high boost (20psi), but I need to take it back to get it re-tuned because something's messed up somewhere in the map
Old Nov 12, 2005 | 12:57 PM
Kerr's Avatar
Default Re: (AntiStock)
a boosted R would be fun
Old Nov 12, 2005 | 02:33 PM
DontBlink's Avatar
Default Re: (Kerr)
GE sleeves,83mm arias pistons 9.0:1,eagle rods, RLD-fab equal length manifold, GT30R turbo .63a/r, 1000cc injectors, thermal 3" exhaust, hondata stage 2db(&lt;--old skool )
471hp 313tq(17psi on pump gas)
517hp 351tq(23psi on race gas)
Old Nov 12, 2005 | 03:26 PM
Haleiwa-Brando's Avatar
Default Re: (DontBlink)
84mm AEBS sleeved block, 9.0:1 CP pistons, Rocket Motorsports rods, Rocket motorsports valve train, St Corsa cam gears, AEM fuel rail, 1000cc injectors, GE vacuum manifold, Full Race Stage 3 Turbo kit with a T3/T67 turbo and .63 A/R. Full 3" exhaust with test pipe. Some other minor *****.
over 500whp at 15lbs.
That was the old setup. Money spent = J0 dun n33d ta' kn0W
Old Nov 12, 2005 | 10:18 PM
tvman's Avatar
i was trying to shoot 300 but looks like everyones passed that...about how much would it cost to get at least 300whp?
Old Nov 12, 2005 | 10:37 PM
Black R's Avatar
25 Year Member
Default Re: (Haleiwa-Brando)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando &raquo;</TD></TR><TR><TD CLASS="quote">
Old Nov 12, 2005 | 10:42 PM
ZygSpeed's Avatar
Google, search or otherwise look up "turbo kit", then look for Acura and then Integra.
Just about any readily available system will net you very near to 300.
Old Nov 13, 2005 | 12:02 AM
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
Never dynoed. Very well estimated by Full-Race, AEBS and Rocket, amongst some tuner shops. Guess that number means nothing.
Old Nov 13, 2005 | 12:58 AM
texastype_r's Avatar
Damn cant wait till mine is done I have a fully built b18c block darton sleeves,arias pistons eagle rods ,aem ems etc...And just waiting until this feb. YEAAAHHH INCOME TAX TIME
Old Nov 13, 2005 | 09:31 AM
Default Re: (texastype_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by texastype_r &raquo;</TD></TR><TR><TD CLASS="quote">Damn cant wait till mine is done I have a fully built b18c block darton sleeves,arias pistons eagle rods ,aem ems etc...And just waiting until this feb. YEAAAHHH INCOME TAX TIME </TD></TR></TABLE>
Are you in college?
Old Nov 13, 2005 | 07:41 PM
BoostR41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvman &raquo;</TD></TR><TR><TD CLASS="quote">search thing is down...so anyone running itr turbo? how much whp you pushing and how much torque? </TD></TR></TABLE>
why not just buy my turbo kit for 1700 and get a hondata and fuel system and make real close to 300whp reliably on a stock block
I did 309whp 242wtq on the 8.8:1 compression motor but my set up did real close to 300whp on stock blocks in this forum.
Old Nov 14, 2005 | 11:27 AM
Finland's Avatar
295whp @ 8700 rpm on Mustang dyno on 100% stock internals.
It lasted a bit over 40K miles before starting to consume oil.
I'll crack it open over the winter to see what failed...probably ring lands.
Old Nov 14, 2005 | 07:06 PM
TypRice's Avatar
im push 446whp
and 350 tq
CraZy-R
Apr 30, 2009 04:53 PM
ITR_HO
Feb 6, 2007 02:45 PM
Outkast_CL9
Jul 5, 2004 05:50 AM
fknfast
Feb 2, 2004 01:02 PM
