In the middle of a cam install, HELP!!!!
Old Mar 10, 2002 | 09:14 PM
nfn15037's Avatar
Default In the middle of a cam install, HELP!!!!
Well, im in the middle of installing some cams and i have run into some trouble. While torquing down the cam cap bolts, 2 of them have snapped. I know its not my torque wrench, as they snapped using 2 different torque wrenches. My question is, do i need to replace all these bolts? i dont think they have ever been out before, but i really need some help here guys. Thanks in advance!!
Old Mar 10, 2002 | 09:50 PM
FSTASNTZ's Avatar
Default Re: In the middle of a cam install, HELP!!!! (nfn15037)
I would replace them all if they are out. If two have snapped, how many more will...
Jason
Old Mar 11, 2002 | 09:27 AM
nfn15037's Avatar
Default Re: In the middle of a cam install, HELP!!!! (FSTASNTZ)
ttt
Old Mar 11, 2002 | 09:29 AM
sgT's Avatar
sgT
make sure you are doing them evenly or else they will snap.
Old Mar 11, 2002 | 09:37 AM
CW-ITR-329's Avatar
Default Re: In the middle of a cam install, HELP!!!! (sgT)
Matt, your in town right? WHat # do I call you at? I'll try to help you out with the install. Ryan
Old Mar 11, 2002 | 10:03 AM
C-speed's Avatar
Default Re: In the middle of a cam install, HELP!!!! (CW-ITR-329)
You sure you set the torque wrench to FT/LBS and not IN/LBS?
Old Mar 11, 2002 | 05:17 PM
nfn15037's Avatar
Default Re: In the middle of a cam install, HELP!!!! (G3-TEG)
Thanks guys, i got it figured out. I wasnt tightening them in steps like i should have!
jansenrw
Aug 24, 2005 03:49 PM
xXx Justin xXx
Apr 1, 2004 07:20 PM
216.226.142.95:27016
Jun 5, 2003 05:55 PM
