brakes cause idle to go down??
Old Nov 11, 2005 | 10:29 PM
92integraVTECgsr's Avatar
Default brakes cause idle to go down??
when im stopped and pressing the brake pedal down, my idle drops a little and the car starts to shake..
what would be causing that?
Old Nov 11, 2005 | 10:59 PM
GSRVTEC1's Avatar
Default Re: brakes cause idle to go down?? (92integraVTECgsr)
maybe your battery is low.. how low does it idle to? if its to 500 then you're normal, if its below that then theres a problem. u can always set your idle point n make it higher
Old Nov 11, 2005 | 11:16 PM
LSvtec03's Avatar
Default Re: brakes cause idle to go down?? (GSRVTEC1)
cars dont run on the battery while they're running. check your alternator output. and yes, adjust your idle and make sure it's set properly.
Old Nov 11, 2005 | 11:34 PM
Dartanian's Avatar
Check the brake booster and check valve. You may have a faulty check valve and/or brake booster.
Old Nov 12, 2005 | 12:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">Check the brake booster and check valve. You may have a faulty check valve and/or brake booster.</TD></TR></TABLE>
that was what i was hoping to hear.. thats what im thinking.. im gonna check my valve tomorrow..
bdr_one
Feb 4, 2015 06:39 PM
4g4dcruisin
Jan 6, 2010 07:33 AM
Tarlacon
Mar 22, 2008 07:48 AM
mc
12
May 24, 2005 03:46 PM
cifer6425
May 19, 2004 10:00 AM
