Using an 89 si clutch with 89 dx tranny and flywheel?
Old Nov 11, 2005 | 05:49 PM
mr_hahn73's Avatar
Default Using an 89 si clutch with 89 dx tranny and flywheel?
Hey guys I need help with this problem. I read that all the trannys 89 and up are 20 spline. My first clutch i ordered was a dual friction dx clutch (Which Sucked). What I read was on an 89 the dx clutch is 190mm and the si is 200mm. 1inch more of material. Has anyone used a SI clutch with a dx tranny and flywheel. I would rather stay with this tranny cause of the longer gearing with boost. Is this true will the si clutch fit with these combos with no problem. I know the 90-91 uses a 212mm so thats out of the question without a newer flywheel. please help!!!
Old Nov 11, 2005 | 05:58 PM
zulued's Avatar
Default Re: Using an 89 si clutch with 89 dx tranny and flywheel? (mr_hahn73)
ok the dx and si clutch disk sizes are the same... its goes by year.
all 89's were the same size.
it will work.
scarponze
shyguy4no1
Feb 12, 2010 12:42 PM
TougeCoupe
Jun 3, 2005 03:27 PM
CRXalwysk8
13
May 3, 2005 07:18 AM
Bond
24
Apr 1, 2005 12:08 PM
sohcvtec66
Nov 18, 2003 09:49 AM
