Honda S2000 Honda S2000
my mechanic cannot get into my clutch box
Old Nov 11, 2005 | 05:31 PM
congo's Avatar
Default my mechanic cannot get into my clutch box
anyone got their clutch replace before? and had the same problem?
the problem is::
my mechanic can not get into my clutch box or tranny box even tho he took out my whole engine cuz the clutch is conected to the engine... but HOW CAN HE NOT get itno the box i do not understand... which is lagging on me.. cuz the car has been dere for almost a week now... it's driving me -->
lol anyone know how to get into the the clutch box ?
thx
Old Nov 11, 2005 | 11:33 PM
fknfast's Avatar
Default Re: my mechanic cannot get into my clutch box (congo)
dude WTF are you smoking.. gimmie some.
Old Nov 11, 2005 | 11:42 PM
Mr. Projekt's Avatar
* B A N N E D *
I think he means he can't separate the bellhousing from the motor. There are 8 bolts total, one being the upper mounting bolt for the starter. That should be the one that he can't find. Then pull out the release fork, the tranny should slide right off with clutch in plain view.
Old Nov 12, 2005 | 04:27 AM
Nishant's Avatar
Default Re: my mechanic cannot get into my clutch box (Slideways2000)
hand him a service manual
Old Nov 12, 2005 | 07:41 AM
* B A N N E D *
Default Re: my mechanic cannot get into my clutch box (Nishant)
Smack him with it.
Old Nov 12, 2005 | 08:46 AM
p nut's Avatar
Then find another mechanic.
Old Nov 12, 2005 | 09:38 AM
fknfast's Avatar
Default Re: (P Nut)
wahahaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
i just shat myself....
Old Nov 12, 2005 | 10:53 AM
solsurvivor's Avatar
Default Re: (fknfast)
LOL
Old Nov 12, 2005 | 12:14 PM
IdotheSHOCKER's Avatar
A little helpful advice:
Make sure all the bolts are off the tranny, especially the top of the housing where you can't see.
If you are sure they are all out and its still not budging you can try to pry it a little with a large flat head screwdriver.
If that doesn't work it may mean that the clutch is somehow stuck on the flywheel, this would mean you may have to undo the clutch pressure plate screws from the opening at the bottom of the tranny. It's a tight fit but manageable, if you are able to unscrew all the screws from the pressure plate than it should break it loose.
Old Nov 12, 2005 | 01:09 PM
fullraceacura's Avatar
Default Re: my mechanic cannot get into my clutch box (IdotheSHOCKER)
wow is your mechanic a 16 year old?
Old Nov 12, 2005 | 01:31 PM
pills_PMD's Avatar
amatuers dude... amatuers
Old Nov 12, 2005 | 01:38 PM
* B A N N E D *
Default Re: (pills_PMD)
Yea no ****. Did all that myself.
Old Nov 12, 2005 | 02:57 PM
SteveoBA8's Avatar
Default Re: (Slideways2000)
your're letting this guy touch your S . no way , wonder how many things are gona be f-ked up when hes done. ohh sorry forgot to tighten that one
Old Nov 13, 2005 | 11:13 AM
fknfast's Avatar
Default Re: (SteveoBA8)
Modified by fknfast at 8:33 AM 11/17/2005
Old Nov 15, 2005 | 09:37 PM
congo's Avatar
ya no kidding...
but i was dere w/ him to help him take out the tranny...
it finally came off...
i told him to check all the bolts and he said that it was all taken out
then i told him to chekc inside the tranny itself
and dere he found 8 bolts STILL INTACT!!
............. dam... lol
but imma be dere when he put it all back
to make sure that it's all going back right
thanks for feebacks
thanks
Old Nov 16, 2005 | 12:19 AM
* B A N N E D *
Inside the tranny? Hmmm I don't think so. Maybe he forgot to pull the release fork or something. I'm pretty sure its that bolt thats hidden by the starter.
Old Nov 16, 2005 | 01:13 AM
blackdelslo's Avatar
do everyone a favor and find a mechanic that knows how to take transmissions off motors
Old Nov 16, 2005 | 01:31 AM
* B A N N E D *
Did he pull your motor and tranny as one piece? If so, when he puts it back in, check for damage to the VTEC solenoid and the IACV. If there are dents or scratches, make him replace it.
Old Nov 16, 2005 | 05:33 AM
hypnosisracing's Avatar
Are you seriously and purposely using "dere" as THERE? omg man...what the hell?
Old Nov 16, 2005 | 07:01 AM
jolt-tsp's Avatar
Default Re: my mechanic cannot get into my clutch box (hypnosisracing)
I think I understand what is going on. The clutch box is a box inside the transmission that powers a robot called the Prop Shaft Cowboy. The Prop Shaft Cowboy's job is to make sure no one removes the clutch. So before removing the clutch you need to open the clutch box and turn off the PSC.
/very boring morning here.
Old Nov 16, 2005 | 08:37 AM
* B A N N E D *
Default Re: my mechanic cannot get into my clutch box (jolt-tsp)
I'd be scared if that guy works on my Caravan.
slowwhitehatch
Sep 16, 2010 03:44 AM
GetawayInMoscow
May 3, 2007 07:06 PM
crvtkllr
Sep 29, 2006 06:03 PM
IVI
Dec 13, 2004 09:19 AM
Thrillhouse
Aug 16, 2002 11:19 AM
