b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles
Old Nov 11, 2005 | 02:51 PM
doublejz's Avatar
Default b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles
well like the topic says i have
b16 in a 93 couple with skunk2 lowering springs and skunk2 camber kit.
It almost seems like the axles are an inch too short and keeps binding and blowing axles. I go through a set like ever 2 months. They bind in ever turn. I have tried pepboys, autozone and now I am on raxles one. Probably have about 100 miles on them and they are about shot. I left the 93 couple spindles on and I am using Del Sol Vtec axles. Anyone else have this problem or a solution???
Old Nov 12, 2005 | 05:52 AM
doublejz's Avatar
Default Re: b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles (doublejz)
bump
Old Nov 12, 2005 | 06:35 AM
Goinfasterthanu's Avatar
Have you checked the motor mounts?...they can be shot with out being ripped..
Old Nov 12, 2005 | 10:13 AM
doublejz's Avatar
Default Re: (Goinfasterthanu)
just put in a new hasport drivers side, jdm **** passenger side and the rear one is till the same that came outta a 94 sol. *shrug*
Old Nov 15, 2005 | 09:55 AM
doublejz's Avatar
Default Re: (doublejz)
one of my friends mentioned that he had to change the actual bracket on the block my the cam gears along with mount... anyone else do this?
EJ7CoUpE
Oct 16, 2008 01:00 PM
teggytegteg
May 16, 2004 11:41 PM
crxhybrid90
Dec 28, 2003 12:00 PM
_Not_So_Nice_Guy
May 22, 2003 06:48 AM
kangjin
Feb 7, 2002 10:07 AM
