b17 crx
Similar to a 1g b16a swap except it is OBD1 and has slightly more torque due to the extra displacement over the b16a. It is a good swap and is performed the same as any other b series swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SuperLudeSI »</TD></TR><TR><TD CLASS="quote">I gotta find more information on the b17 do any of you guys no anything.</TD></TR></TABLE>
Umm. What do you want to 'no' ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">what kinda information? Yeah its obd1 so keep it obd1. The mount kit, and linkage should be the same as the b16. Its bascially the same engine</TD></TR></TABLE>
just lil more badass
b17 swaps are so badass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SuperLudeSI »</TD></TR><TR><TD CLASS="quote">I am putting a b17 gsr motor in a 1991 crx si? what do you guys think of the swap? I am going to rebuil the motor first. </TD></TR></TABLE>
If your going to re-build that B17 please do it with high performance work on it . . take care of that U.S. motor it would be nice to see u hit high 12's or low 13's with it in a CRX truely tho i've seen alot of ppl make those motors seem useless because its USDM, with a v-tec head that makes it look even ko0o0oler. but yeaz just do a pretty darn good job !
Yea it is going to be done right. I am getting skunk2 valves and valves spring. I am putting rings and new pistions in the b17. It going to be nice when i am done. I gotta order a 7 pound flywheel this week and a clutch but i really aint sure what clutch to use tho.
It's a decent swap, and it's not common. I used to have a B17 in my 90 hatch. Keep it OBD1.
Should be pretty quick I saw a guy in a stripped EF hatch hity 14 flat all da ylong with just the motor and a DC sports header, stock air box and stock exhaust so it has good potential.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SuperLudeSI »</TD></TR><TR><TD CLASS="quote">What is wrong with the 7 pound flywheel?</TD></TR></TABLE>
if it is going to be a street car the 7 lb fly will not be a good choice...i can get detailed with it, but simply put, the motor does not produce enough torque for that light of a flywheel to be effective...it will actually be worse than ur stock one for everyday driving...i would go with the next heavier one...i believe its like 11 or 12 lbs. its heavy enough that the extra mass will keep the momentum so there is no fluxuation in your rpm going up or down hills...honestly the only car i would put a extremely light fly in would be a drag car...since its only function is to accelerate...the lighter the better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">
if it is going to be a street car the 7 lb fly will not be a good choice...i can get detailed with it, but simply put, the motor does not produce enough torque for that light of a flywheel to be effective...it will actually be worse than ur stock one for everyday driving...i would go with the next heavier one...i believe its like 11 or 12 lbs. its heavy enough that the extra mass will keep the momentum so there is no fluxuation in your rpm going up or down hills...honestly the only car i would put a extremely light fly in would be a drag car...since its only function is to accelerate...the lighter the better</TD></TR></TABLE>I run a 8 lbs flywheel on my b16a and I love it. Screw the internet junkies that don't have real life experience but just read articales all day long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94SuperLudeSI »</TD></TR><TR><TD CLASS="quote">i am going to go with the 7 pound flywheel i think.</TD></TR></TABLE>
I have a 7.5 lb flywheel..And to be honest it's cool..Just the revs fall alot quicker but the motor doesn't cut out like most people say..Acceleration is better in first and 2nd..
