Lower control arm question
Old Nov 11, 2005 | 12:06 PM
EKIM NART's Avatar
Default Lower control arm question
I used DC integra front hub and brake assembly to swap a b-series in my 88 HB. I kept the civic lower control arms and now my camber is messed up. I ordered a camber kit but that didn't help at all. Could i use the DC integra LCA to fix the camber problem? Searched but the search server is down.
Old Nov 11, 2005 | 12:09 PM
EL Vap133's Avatar
Default Re: Lower control arm question (N ef A)
I would suggest you use DA knuckles instead.
Old Nov 11, 2005 | 12:25 PM
EKIM NART's Avatar
Default Re: Lower control arm question (EL Vap133)
thats all could get my hands on at that time.
Old Nov 11, 2005 | 12:47 PM
JohnnieChimpo's Avatar
The search isn't down. It is working fine someone is asking it 4 questions a minute. The mods need to wake up and block that IP address.
The DC spindles will bolt on but they don't work.
Any EF spindle will work as long as it isn't from a 4 speed or a HF.
The DA ones will work too.
DCs will fit an EG but not us.
Chemi421
Suspension & Brakes
11
Aug 30, 2017 04:25 PM
JDM JEFFREY
Nov 30, 2010 06:18 AM
civicgeek133
Suspension & Brakes
12
Nov 26, 2006 06:40 PM
EFB16aJP
Oct 6, 2005 06:27 PM
magnumdad
Suspension & Brakes
May 4, 2005 08:48 AM
