DC4...studda, studda, studda
Old Nov 11, 2005 | 11:30 AM
jDm_jeremy's Avatar
Default DC4...studda, studda, studda
like the title says.....under acceleration i have a stuttering, misfiring situation happening. Only happens when below 3000 RPMs, 1/2 to full throttle, AND in closed loop.... Yeah that's the thing that f'n with me....when the car is cold it runs perfect, but when it warms up studda, studda. Anyone had a similar prob??
My guesses are.... Oxygen Sensor...clogged fuel filter.
need suggestions please....
Thanks
Old Nov 11, 2005 | 07:27 PM
97tegGS's Avatar
I would say FF. If possible just check your timing.
Old Nov 11, 2005 | 08:03 PM
Sack Master's Avatar
Default Re: (97tegGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDm_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">My guesses are.... Oxygen Sensor...clogged fuel filter. </TD></TR></TABLE>I've seen both those cause that same problem.
I also had that same exact problem with my car. After I changed the o2 and fuel filter, along with about everything else ignition. It turned out to be my less than a year old NGK wires .
Could also be a clogged injector.
Old Nov 11, 2005 | 08:55 PM
-Todd-'s Avatar
Default Re: DC4...studda, studda, studda (jDm_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDm_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">like the title says.....under acceleration i have a stuttering, misfiring situation happening. Only happens when below 3000 RPMs, 1/2 to full throttle, AND in closed loop.... Yeah that's the thing that f'n with me....when the car is cold it runs perfect, but when it warms up studda, studda. Anyone had a similar prob??
Thanks </TD></TR></TABLE>
My car's the same way. Put a new fuel filter on it... fixed it for about a week, then it returned. Put new plugs and wires on it, still does it. I'd try and put a new fuel filter on it first.
Old Nov 11, 2005 | 09:01 PM
dcb16's Avatar
First: Try unplugging your 02 sensor connector, if the problem is the same, most likely its your 02
Second: I would check your 02 circuitry. Let your DMM and helms diagram schematics lead the way. See if you can get the testing procedures for your 02.
Third: try borrowing a known good sensor
let us know!
Old Nov 11, 2005 | 10:09 PM
dcb16's Avatar
Default Re: DC4...studda, studda, studda (dcb16)
JESUS! I wasnt even thinking... CHECK UR TPS!!!
that is the easiest sensor to check. 5V reference, Ground, Signal.
also, check for soft codes that might be stored in the ecu use a paper clip on the 2 wire jumper underneath the glove box to pull the codes (if u got obd2, ur SOL)
to check the TPS:
Signal: KEY ON ENGINE OFF, positive lead on red/black, negative on known good ground (- side of batterty) Should be 5v
note: the sensor needs to be connected to the connector clip (use a pin to probe into the connector)
Reference: KEY ON ENGINE OFF, positive lead to the yellow/blue wire and the negative lead to the green/black. once connected it should read .5 volts. SLOWLY increase throttle position. the voltage should go up with the throttle plate opening. If you see a voltage jump when you are doing this, have it further inspected, with someone with proper tools (like a scanner or a Vantage). But if the voltage doesnt move at all, then your sensor is f'ed. replace it. good luck bro. IM me if u need more help.
Old Nov 12, 2005 | 12:13 AM
SlammedDC2's Avatar
Semper Fidelis
Check your ecu mine went bad and it did the same thing.
Old Nov 12, 2005 | 08:47 AM
jDm_jeremy's Avatar
Thanks everyone ....i think i'll try to start at the least expensive fix and work my way up.....fuel filter first, then Ox sensor, and might as well change plugs and wires while i'm at it.........and hope like hell its not the ECU
i'll post what i find
Old Nov 12, 2005 | 11:53 AM
jDm_jeremy's Avatar
Default Re:
the thing that's i dont understand is why it runs great in open loop [ when cold ]??
i think that would eliminate the fuel system all together....weird problems suck
Old Nov 14, 2005 | 03:21 AM
jDm_jeremy's Avatar
Default Re: Re: (jDm_jeremy)
^^bump^^
Old Nov 14, 2005 | 07:17 PM
dcb16's Avatar
did you acually try testing your TPS????
Old Nov 14, 2005 | 07:22 PM
scottishdave's Avatar
My car used to do that but only at 100% throttle, and 95% i was ok. It wound up being my tps sensor.
My friends GSR also had the same problem but only on occasion. It wound up being his sparkplugs.
I would check fuel filter though and then injectors. Sometimes at high rpm fuel is flowing fast enough to not be affected much but at low rpm the filter could be affecting it. There is my 02 hope it helps.
Old Nov 15, 2005 | 03:07 AM
jDm_jeremy's Avatar
Default Re: Re: (dcb16)
tps sensor is a good idea....haven't checked yet been busy with work.....will check and post
thanks
Old Nov 15, 2005 | 03:09 AM
jDm_jeremy's Avatar
Default Re: Re: (scottishdave)
thanks brah...yeah, this is one of those problems that could be anything.....SUX
Old Nov 16, 2005 | 06:36 AM
jDm_jeremy's Avatar
Alright, here's the deal.....tomorrow I've got one shot at fixing this thing, one item [ limited cash b/c i'm buying a house ] if the TPS is good, i could either get plugs & wires, or a fuel filter, or a OX sensor..... not sure which one to get, but i've got one shot for two weeks so i better make it count. if not i'll just drive along real slow on take-off. What do you guys think would be the best bet?
Old Nov 16, 2005 | 11:08 AM
jDm_jeremy's Avatar
Old Nov 17, 2005 | 08:51 PM
dcb16's Avatar
Default Re: (jDm_jeremy)
buy something u cant test, fuel filter should be first, assuming you have already checked the plugs and they are ok. (when was the last time the fuel filter was replaced, its supposed to be done every 30k) i would also check the air filter.
to check the injectors, put the voltmeter on the ground side of the injector (YES, THE GROUND SIDE!!) it should read 12v consistantly. make sure to use a pin to probe the injector connector
although i really dont think it's an injector, i just thought i'd let you know if u wanted to test it while your in there
EDIT: i really dont support throwing parts at cars, i sugguest you
first: check air filter
second: look at plugs (btw: are they the proper heat range???)
third: test 02 sesnsor, tps, and map sensor
fourth: if you havnt found a problem yet, take it to a shop and pay a diagnostic fee, it will save you the money from throwing parts at it.
Old Nov 18, 2005 | 04:32 AM
jDm_jeremy's Avatar
Default Re: (dcb16)
Update: gave the car problem more time to present it's self and realized that what was really happening was my #4 cylinder was dropping out on spark advance....Replaced plugs and wires.....BING, BING: we have a winner!! #4 plug had a crack in the porcelain and was arching through. Everything else checked out fine.. PROBLEM SOLVED Thanks everyone
jhony_ej6
Jul 11, 2008 09:55 AM
GSRinGER
Jan 9, 2008 10:25 AM
erottik-R
Sep 15, 2006 11:03 AM
elpiar
Sep 16, 2005 06:09 AM
Cone
Jun 1, 2003 08:46 PM
