Hoses behind intake manifold!!!! ahhhhhhhhh
This is off my crappy memory, so don't take it as gospel. There is a hose to the pcv that goes to the oil breather with air/oil vapor mixture. Then there is a bypass hose that comes out of the head and back to the head or block, not sure. Then there are two hoses that goes into and out of the throttle body I believe that is coolant.
I had a small leak in one of those hoses that was causing me to loose enough coolant to overheat. So I replaced all of them, hose is cheap, and upgrade the clamps also while you are there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg »</TD></TR><TR><TD CLASS="quote">I had a small leak in one of those hoses that was causing me to loose enough coolant to overheat. So I replaced all of them, hose is cheap, and upgrade the clamps also while you are there.</TD></TR></TABLE>
i would go with what he said and replace them all and the clamps...
TrueUntilDeath.com
Jan 25, 2008 03:38 PM
