What piston ring for wiseco fordged piston
Old Nov 11, 2005 | 08:39 AM
DC2TT's Avatar
Default What piston ring for wiseco fordged piston
I need to replace my ring but don't know what piston ring to use beside wiseco piston ring? It is a wiseco turbo piston (forged) i need to know what piston ring i may replace instead of wiseco,may i use original?
Old Nov 11, 2005 | 12:23 PM
tegman2's Avatar
Default Re: What piston ring for wiseco fordged piston (DC2TT)
what size is your piston?? I have a set of 81.5mm JE rings that would work that I would be willing to let go cheap.
Old Nov 11, 2005 | 12:25 PM
SOHCD16y8's Avatar
I use Je rings in my motor and couldnt be happier, Ive also used total seal but I like the Je's better for some reason. I would pick those up if I were you.
Old Nov 11, 2005 | 01:11 PM
Flamenco-T's Avatar
Default Re: (SOHCD16y8)
We have plenty of Wiseco piston ring set in stock...just let me know if you need some..
Stan
877-988-8726
Old Nov 11, 2005 | 02:17 PM
ZC1.8crx's Avatar
Default Re: (Flamenco-T)
hastings
Old Jan 9, 2006 | 09:53 AM
DC2TT's Avatar
people who use wiseco piston please kindly let me know what piston ring i can use, and do you need to change the size of piston if the ring is crack or may i just replace the ring, my comp on 3 pistons are good about 200 but one of them doesmt show comp easily.
Old Jan 9, 2006 | 11:19 AM
JDogg's Avatar
never had a problem with wiseco rings...
Old Jan 9, 2006 | 11:38 AM
urbansi's Avatar
Default Re: What piston ring for wiseco fordged piston (JDogg)
i am currently waiting to put in my wisco 81.50mm pistons, the ring number is 1023055
http://www.we-todd-did-racing....x.jpg
Picture of Rings^^^
Old Jan 9, 2006 | 02:03 PM
simike's Avatar
Default Re: What piston ring for wiseco fordged piston (urbansi)
Wiseco pistons and rings here. So far they both have performed very well.
Old Jan 9, 2006 | 07:43 PM
T Dohc's Avatar
Another set of rings to check into is the SpeedPro Hellfire series they are some of the best on the market.
Old Jan 9, 2006 | 07:47 PM
1epmugenlude's Avatar
I used the rings that came with the wisecos I have..
blackeg
Mar 11, 2013 03:16 AM
RACEPAK
Aug 30, 2008 09:59 PM
95blackEG
May 23, 2007 02:50 PM
DC2TT
Nov 11, 2005 10:44 AM
