camber kits???
Old Mar 10, 2002 | 05:51 PM
vtec-outlaw's Avatar
Default camber kits???
Hey guys help me out. Im looking to get a camber kit for my car. Everything that I read says that integras and front wheel drive cars in general, typically dont have a stock front cambers...makes sense, but nothing is ever said about the rear. Do I need a camber kit for the rear as well or does the rear already have one on it????????? What is a good camber kit for the money??
Old Mar 10, 2002 | 07:26 PM
ebelp's Avatar
Default Re: camber kits??? (vtec-outlaw)
Typically a camber kit is needed more for the rear than for the front. Also, from what I hear, Ingalls is the most popular brand. But a camber kit is just a camber kit, right??
Old Mar 10, 2002 | 07:38 PM
neo1z's Avatar
Default Re: camber kits??? (ebelp)
i about 100% disagree -- on the g3 tegs the front is much more prominant than the rear (i can vouch because i just had my car at the alignment shop, and got yelled at for having hella bad front camber, im on H&R sports by the way)
and ingalls is the most well-known, whether or not they are the best is up for question. just rotate your tires alot (if u dont wanna spend 150)
Old Mar 10, 2002 | 07:41 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
Default Re: camber kits??? (neo1z)
you can buy them used for like 50 bucks. front is more important if you want your wheels to last longer since you turn with them and put power to the ground with them. rear can be done for free
Old Mar 10, 2002 | 07:52 PM
ebelp's Avatar
Default Re: camber kits??? (boroDC2)
Funny...most situations I've seen with lowered cars, the rear tires wear and the front tires are fine. I guess it just depends on the spring/car combination.
Old Mar 10, 2002 | 07:58 PM
Erik_Pb_Foot's Avatar
New User
Ingalls is the choice by many. Front and rear need it for tire wear... and for handling really. don't do a half *** job on your suspension... you're putting your own life, and others, at risk. what happens when the ground is wet and you loose control b/c your tires aren't making full contact with the asphalt?
Old Mar 10, 2002 | 08:57 PM
boipika's Avatar
For the back, u can add washers to ur camber. I did it to my car, and my cambers are really straight in the back. Costed me couple cents, go to home depo. I put 2 washers in the back andi lowered it like 2.25 inches.
Old Mar 10, 2002 | 09:47 PM
New User
Default Re: camber kits??? (boipika)
Some people might laugh at your solution, but it is a perfectly valid way to fix rear negetive camber. Just be sure to use longer bolts when inserting washers. This fix is great for 1-1.5" drops or so... For any sever drop the camber kit would be recommended. But shoot, washers are great until you have time to get the kit. Be sure to always get a 4 wheel alignment at a reputable shop when lowering your vehicle. It is best to lower it, let the new springs compress for a week or so, then bring it back to get the alignment done. Also, it is best to be sitting in your car when you mechanic does it so that it is aligned correctly with your weight in the car.
Old Mar 10, 2002 | 09:56 PM
boipika's Avatar
Default Re: camber kits??? (Pb_Foot)
yeah i got my alignment done right away after i dropped my car with the camer kit cause my car's alignment was so off it was barely driveable. My tires were screeching just driving straight. And about the Washers, i kept my stock bolts and it worked just fine. I dont think im really gonna worry about that, just gonna leave it alone. Thanx for the great info thou!
Old Mar 11, 2002 | 07:49 AM
justagsr's Avatar
Yes, you need a camber kit if you don't want to wear out your tires and want to do the job right after lowering your car.
97 Honda Civic- progress (front), GSR (back)
98 gsr-t just ordered ingalls for front and back
I would go with ingalls or progress and just make sure if you lower your car more than 2.25" to get the adjustable arm for the back and not just the washers and a longer bolt. Tried that on my Civic and it didn't change the camber enough at all.
Old Mar 11, 2002 | 07:53 AM
GSRaCeRbOI's Avatar
for the rears you can just go ghetto like i did and use washers from home depot.. it cost like 7 cents (literally) each... you just place them between where the upper suspension arm mounts to the cars body/frame... you MAY need to get longer bolts.. in my case i didnt... i forget the size.. could have been 1/2" washers.. but DON'T quote me on this as I did this a few years ago and i really cant remember the size of the washer... i'll spend money on quality parts and mods.. but to pay like $100 for 2 plates (1 on each side) forget that...
also make sure your Toe angles are in check when you get your alignment.. this helps A LOT w/ tire wear.... my car is lowered and has some negative camber.. but I keep my toe angles in check (by getting an alignment) and i rotate my tires every oil change (every 3K).. yeah its excessive..but my wear is pretty normal/even.. so its all good
[Modified by GSRaCeRbOI, 4:54 PM 3/11/2002]
Old Mar 11, 2002 | 08:34 AM
keys's Avatar
Default Re: camber kits??? (GSRaCeRbOI)
I've been using the washer method in the rear for quite some time now, and from my experience it works great. Camber is fine and it's sturdy. As for the fronts I use Ingalls and I can also vouch for them.... my friend had progress camber kits and it didn't look like you could adjust it like the Ingalls.... I think the Progress kit only had 2 settings to choose from.... HTH
Old Mar 11, 2002 | 09:12 AM
boipika's Avatar
Default Re: camber kits??? (keys)
I Agree
Old Mar 11, 2002 | 01:49 PM
Philbert's Avatar
Default what about the skunk2 camber kit?
i have seen the skunk2 camber kit which replaces the upper control arm and has a sliding ball joint. costs around $200 for the front kit. does anyone have experience with these?
thanks,
phil
Old Mar 11, 2002 | 07:23 PM
Spyderwebab's Avatar
Ingall's Camber kit for the front Have the tire shop shim the rear
Old Mar 11, 2002 | 09:29 PM
ebelp's Avatar
Default Re: camber kits??? (Spyderwebab)
Can someone show me a pic of where I would put the washer to correct the rear camber? I can't visualize where you guys are talking about.
Old Mar 11, 2002 | 09:36 PM
Aeka GSR's Avatar
New User
i got a cheap *** kit. The center nut with the offset hole keeps sliding back and forth in the housing causing it to knock against inner sides of the a arm when weight is shifted. pain in the ***.
ingrate's Avatar
25 Year Member
progress user here.. yeah only 2 settings but then again how many times do you need to adjust the camber?
for the rear washer trick, look at the upper control arm where it attaches to the gas tank. there's 2 bolts connecting it.
Old Mar 11, 2002 | 10:41 PM
far's Avatar
far
Default Re: what about the skunk2 camber kit? (Philbert)
thanks,
phil
i just bought those for my 98 gsr. im gonna be dropped on H&R race springs and neuspeed koni yellows. i should be getting everything installed in the next few days so ill let you know.
Old Mar 11, 2002 | 11:16 PM
confucius's Avatar
Default Re: what about the skunk2 camber kit? (98tegsr)
ingallz suck. i have the front camber kit, and u know what, it beats up my car pretty badly. cause i have two new dents under my hood, (right above the ingallz camber kit) and the paint is not chipping off were the dents are forming.
my god.
and for the rear, i am getting the sprint rear camber kit. its only 70 bucks. and i dont think a few washers will help me out. cause the left wheel is pretty damb slanted. ( cause a tow truck hit my car once, on the left side).
the right wheel is kinda straight.
Old Mar 11, 2002 | 11:31 PM
boipika's Avatar
Default Re: what about the skunk2 camber kit? (confucius)
ingallz suck. i have the front camber kit, and u know what, it beats up my car pretty badly. cause i have two new dents under my hood, (right above the ingallz camber kit) and the paint is not chipping off were the dents are forming.and for the rear, i am getting the sprint rear camber kit. its only 70 bucks. and i dont think a few washers will help me out. cause the left wheel is pretty damb slanted. ( cause a tow truck hit my car once, on the left side).
oh crap, is that where the dent is coming from? i have sprint camber kit on the front and i got a dent under the hood too, near my shock area. My paint is chipping off around that area also. Is that dangerous?
Old Mar 11, 2002 | 11:35 PM
far's Avatar
far
Default Re: what about the skunk2 camber kit? (boipika)
yea someone told me about that so i got the skunk2 ones cause i herd they dont do that... goodluck with your cars guys
Old Mar 13, 2002 | 09:34 PM
ATeg92's Avatar
Ingalls (http://www.ingallseng.com/) is by far the best.
Also different camber kits adjust the camber in differnt ways. I have talked to the profesionals at Ground Control and they say Ingalls is the best
[Modified by ATeg92, 6:35 AM 3/14/2002]
lif3tak3n
Feb 7, 2007 12:38 PM
blk94gsr
Suspension & Brakes
Feb 15, 2006 08:49 AM
fafsa
Apr 6, 2005 03:40 PM
bartek_b
Oct 7, 2003 04:45 PM
Takeoff
Aug 11, 2002 01:08 PM
