New Oil pump gears for forced induction engine build? h22a
Old Nov 11, 2005 | 03:24 AM
djnikko's Avatar
Default New Oil pump gears for forced induction engine build? h22a
Ive read it is recommended to replace these when doing an engine build however when talking to my mechanic he's said hes never had a problem with faulty gears. Can someone please enlighten me as to a reason for changing them? or like the water pump is it done for a little extra security?
Old Nov 11, 2005 | 07:04 AM
h22 civic's Avatar
Default Re: New Oil pump gears for forced induction engine build? h22a (djnikko)
def change
Old Nov 17, 2005 | 02:32 AM
djnikko's Avatar
Default Re: New Oil pump gears for forced induction engine build? h22a (h22 civic)
Change the oil pump gears or change the actual oil pump? Any aftermarket pumps or gears available? Thanks
Old Nov 17, 2005 | 04:19 AM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">Change the oil pump gears or change the actual oil pump? Any aftermarket pumps or gears available? Thanks </TD></TR></TABLE>
u need a whole new pump
the specs, tolerances and clearances inside the pump are too critical for it to work
i just got done modifiying my D series pump for better performance, but that doesnt mean it will flow more, just better.... the inner tolerances have to be withing 0.002-0.006
u get a set of gears on the aftermarket, that didnt had good quality control, and u have a pump that will be too tight and not work, or too loose and not build pressure properly
Old Nov 18, 2005 | 09:05 AM
djnikko's Avatar
Default Re: New Oil pump gears for forced induction engine build? h22a (USDM 4G VTEC)
A whole new OEM oil pump it is, when I recieve the part I shall look into modifying it or probably just leave it well alone.
Ive heard bad things about the prodrive gear, but may look into the Toda gear later down the line
tiksie
Jan 26, 2018 07:01 PM
cvp467
Nov 25, 2006 01:33 PM
StolenTeg
Oct 3, 2004 06:50 PM
Machine1
Feb 8, 2004 07:40 PM
