Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what spring rates? racers advice?
Old Mar 10, 2002 | 05:28 PM
Balrog's Avatar
New User
Default what spring rates? racers advice?
95 heavy civic hb with gsr, should i go with 350lbs front w/ 400lbs rear or 400lbs front with 450lbs rear? street/strip application but mostly strip, i dont have to worry about potholes. anyone have any advice? any weight ideas?
posted twice
but thanks for any advice
Old Mar 10, 2002 | 06:06 PM
civicrr's Avatar
Default Re: what spring rates? racers advice? (Balrog)
I will assume you will only be racing on the track.....Most people here roadrace or auto-x. That is why you haven't gotten a lot of response. Seems to me that the higher rates would help prevent weight transfer better if 1) you can stand them on the street & 2) the shocks you have are up to the task.
Old Mar 10, 2002 | 07:38 PM
Balrog's Avatar
New User
Default Re: what spring rates? racers advice? (civicrr)
thanks for the reply. this is my goal, weekend racer kind'a thing. your right, i will just have to decide how far i can go with the rates, i was just hopeing to hear someone who might know some real numbers, you know, something they use themselves to tell me how they like it.
Old Mar 11, 2002 | 11:02 PM
Trickturn's Avatar
Ive been using 400 f & 450 R for a while now. Perfectly streetable to me.
I want 500 & 550 now. Dont get AGX shox. They wouldnt hold up to the 450 lb task, so I can imagine higher rates. Look into some Bilstein shox or Koni yellows.
Pete
Old Mar 14, 2002 | 06:05 AM
Evan55's Avatar
Default Re: what spring rates? racers advice? (pest)
wow 500 in/lb??!! on a light little honda??!!
That sounds like it would rattle your teeth out!
Anyway maybe Im just used to the WRX crowd, where 225 in/lb is considered firm. (and on a 3000 lb car)
Old Mar 14, 2002 | 06:43 AM
.RJ's Avatar
.RJ
Default Re: what spring rates? racers advice? (elgorey)
****... i think warren is running 600/900 lb springs. The real time ITR guys were running springs 1000-1200 lb/in in the rear i believe.....
Old Mar 14, 2002 | 10:18 AM
Evan55's Avatar
Default Re: what spring rates? racers advice? (Type-RJ)
those arent street cars or daily drivers though right?
Im about to buy some cusco coilovers, with my only reservation how stiff the springs are. How unbearable is 492in/lb on a daily driver?
Old Mar 14, 2002 | 10:56 AM
.RJ's Avatar
.RJ
No, those are race cars... get the coil-overs, dont worry about comfort (he says as the springs on his saturn are stock, at 125 lb/in.... ) Actually, in all honesty i'd get a few autocrosses and an evolution school done before i'd make major changes to the car... and then you can go back and do the phase 3 autoX school to get the coil overs dialed in
RJ
Old Mar 14, 2002 | 11:13 AM
SPiFF's Avatar
My 400/550 set-up feels fine driving around. Granted I have only driven it:
* Back from the shop
* To and from the alignment place
* To and from one AutoX
There are plenty of idiots who drive around on cut springs riding on the bumpstops. I don't see how riding on a well setup but hard suspension is bad.
Well worth it when you get out on course. I can't wait to get this setup on track in April.
[Modified by SPiFF, 3:14 PM 3/14/2002]
Old Mar 14, 2002 | 11:30 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Re: what spring rates? racers advice? (SPiFF)
And his car now seriously kicks some *** on an autocross course.
BTW, thanks agian for the ride Zsolt!
motoxxxman
Suspension & Brakes
23
Mar 25, 2016 10:18 AM
zerovandez
31
Jan 7, 2007 04:13 PM
Makdaddynuge
Suspension & Brakes
Dec 6, 2005 04:02 PM
Dyzee
May 1, 2004 05:35 PM
Balrog
Mar 11, 2002 05:31 PM
