Exhaust mani for 2.0L high compression engine
Old Nov 10, 2005 | 11:52 PM
Haleiwa-Brando's Avatar
Default Exhaust mani for 2.0L high compression engine
I know this topic has been beaten like a dead horse. Bare with me. I've ordered a header from Hytech which they say is good for a 2.0L high compression engine. I'm simply thinking if I'm going to spend a wad of cash on a header, is there anything out there in your opinion that I should consider and why?
I've been looking at:
Mugen (both headers)
Toda
SMSP
DTR
Hytech
I suppose to better assist in this post, my requirements are going to be gains in the mid and top end. Though I think that's a given.
I've tried to find flow charts, comparrison charts, testimony of 'before and after' and have come up with nothing. It's an expensive part and simply want to make a well educated descision.
Thanks to all that view
Aloha,
Brandon
(Chris F want to do some spell checking? )
Old Nov 11, 2005 | 12:22 AM
RagingAngel's Avatar
Default Re: Exhaust mani for 2.0L high compression engine (Haleiwa-Brando)
The only headers worth looking at the ones that aren't from the JDM manufacturers in your list.
(in no particular order)
SMSP
DTR
Hytech
I would add RMF to this as well.
The primary reason I state this is not because I think Mugen/Toda are junk, but rather they never designed their headers to run with a 2.0L applications. Only the USDM tuners have taken Honda power production so seriously to warrant (in this particular discussion) custom headers to be built.
Again, not saying the Mugen/Toda headers won't work....it probably won't allow your motor to reach its intended potential.
Old Nov 11, 2005 | 04:36 AM
Eva01's Avatar
Definately I would go with custom header for 2L. I know that both Hytech or SMSP have designed headers which have been optimized for a 2L. Personally, I would go Hytech but I'm biased.
Old Nov 11, 2005 | 04:46 AM
Kengs's Avatar
Default Re: (Eva01)
Don't forget Burns Stainless; Casey posted one of their one-off jobs in the All Motor forum.
Old Nov 11, 2005 | 04:58 AM
Bradstard's Avatar
I've got a custom built AN-R with a 3" collector. I've never dyno'd it against anything else although I almost bought the Hytech. Honestly though, with any of the good ones (Hytech, SMSP, DTR, RMF, AN-R) you'll make good power. Stay away from the JDM crap...
Old Nov 11, 2005 | 05:16 AM
Aquafina's Avatar
Default Re: Exhaust mani for 2.0L high compression engine (Bradstard)
SMSP
Header builder who road races.
Old Nov 11, 2005 | 07:27 AM
Ekasey's Avatar
https://honda-tech.com/zerothread?id=1426596
Old Nov 11, 2005 | 07:29 AM
DIFFUT'S INC.'s Avatar
Default Re: Exhaust mani for 2.0L high compression engine (Casey@Burns)
RMF all the way one of the best headers made today 2.5" for street/track or 3" for all track
Old Nov 11, 2005 | 08:55 AM
Black R's Avatar
25 Year Member
If you've already ordered a hytech, then the point is moot. Just make sure he knows it's for a 2.0L and your intended stroke, bore, cams, and compresssion + head flow numbers.
And the expression is "bear with me," not "bare with me" - I don't want to 'bare' with you, period.
Old Nov 11, 2005 | 09:03 AM
Pondus's Avatar
Default Re: (Black R)
This is true, tell John about your setup and he will build it to match, I guarantee you won't be dissapointed. I have a custom Hytech on my 2.1L engine and it seems to be working good. Just be prepared for a bit of waiting
Old Nov 11, 2005 | 09:04 AM
clayton bigsby's Avatar
found this he is from seattle
http://hondamarketplace.com/zerothread?id=1427935
Old Nov 11, 2005 | 09:23 AM
Dr Pooface's Avatar
Doesn't Hytech use some "unique" technology such as anti reversion chambers and super secret patented designes?
I think you went the right route, Brandon. A little $$$$ for my liking, but the quality will definately be there.
I might get my car running before you do
Old Nov 11, 2005 | 09:28 AM
rhd's Avatar
rhd
hytech can't even TOUCH the power an RMF or SMSP can produce
personally...RMF would be my choice
next would be SMSP
after that..they all pretty much suck
Old Nov 11, 2005 | 09:29 AM
Reid's Avatar
Global Moderator
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">hytech can't even TOUCH the power an RMF or SMSP can produce</TD></TR></TABLE>
Where's your proof of this?
Old Nov 11, 2005 | 09:32 AM
rhd's Avatar
rhd
5,000 dyno charts all over the internet. customers chaning out cause they want more power. hanging out at 2 different dyno's and seeing it first hand
Old Nov 11, 2005 | 09:34 AM
Reid's Avatar
Global Moderator
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">5,000 dyno charts all over the internet. customers chaning out cause they want more power. hanging out at 2 different dyno's and seeing it first hand</TD></TR></TABLE>
So do you have any dyno comparisons?
I'm not doubting you, but if you're going to make such a bold claim you have to back it up with evidence.
Old Nov 11, 2005 | 09:40 AM
Black R's Avatar
25 Year Member
Default Re: (rhd)
next would be SMSP
after that..they all pretty much suck</TD></TR></TABLE>
is ignorance truly bliss?
Old Nov 11, 2005 | 09:41 AM
Kendall's Avatar
Default Re: (rhd)
From what I understand, John builds most of his headers for stock motors and any additional change in volumetric efficiency will adversely effect the power potential of his headers. If you had John custom build you an application specific header that took into account every detail of your build, then you'd make excellent power with it until you did something that again changed the VE. There's no doubt that Dave and Randy build outstanding headers, but just because John does it differently (and often making "picky" headers in the process) doesn't mean that his products are inferior.
Old Nov 11, 2005 | 09:48 AM
jakeiscool's Avatar
Banned
Default Re: (Kendall)
Dyno charts plz
Old Nov 11, 2005 | 10:02 AM
NorthernXposure's Avatar
Default Re: (JakeIsCool)
i have made 230+ whp on my 2.0 w/ a JUN header... and while it may not be the best out there.. you cant argue w/ the numbers.. makes me wonder if i could pull 240 out of it with a custom header and testpipe
Old Nov 11, 2005 | 10:54 AM
92TypeR's Avatar
FSAE
Default Re: (NorthernXposure)
Brandon did you order a HyTech? Is it going to arrive here soon?
HyTech does offer a 2.0L header, and it will be better compared to another off-the-shelf header.
However, the DTR, RMF and SMS both will produce more power than the HyTech 2.0L, at least from the charts I've seen. But when it really comes down to it, the difference isn't huge, and if you've already ordered the HyTech I would just stick with what you paid for.
If the header is coming here, I can always do a dyno comparison with my motor
Old Nov 11, 2005 | 02:35 PM
Pondus's Avatar
Default Re: (92TypeR)
Unless tested on the same engine, on the same dyno and preferrably also the same day I would think it's hard to back up these claims, can we all agree that all the headers mentioned will give good power?
Old Nov 11, 2005 | 03:04 PM
itr1244's Avatar
Default Re: (Pondus)
my motor is not 2.0L but this header will work i guess
Old Nov 11, 2005 | 03:18 PM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote"> Stay away from the JDM crap...</TD></TR></TABLE>
crap?
Old Nov 11, 2005 | 03:33 PM
seek167's Avatar
Default Re: Exhaust mani for 2.0L high compression engine (Jon D)
i'm a smsp guy
