how do you take out the pully from the crank that the t-belt runs off?
Old Nov 10, 2005 | 09:44 PM
the.hamburglar's Avatar
Default how do you take out the pully from the crank that the t-belt runs off?
i think its about a 22tooth pully attached to the crank that spins the timing belt. how does this come off? i somehow got the crank out with it attached to the pully but i wanna see the bearing so that pully needs to get off
Old Nov 10, 2005 | 10:25 PM
lohatch's Avatar
Default Re: how do you take out the pully from the crank that the t-belt runs off? (the.hamburglar)
it should slide right off. there will also be a keyway, remove that and slip it off.
Old Nov 10, 2005 | 11:37 PM
Default Re: how do you take out the pully from the crank that the t-belt runs off? (lohatch)
its on there tight. ill try hitting it with a hammer tommorow
Old Nov 11, 2005 | 05:48 AM
2quikmotorwerks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">its on there tight. ill try hitting it with a hammer tommorow</TD></TR></TABLE>NO DO NOT HIT THE CRANK OR THE GEAR WITH A HAMMER U'LL RUIN THEM!!! try soaking the gear with wd40 or something similar or maybe try heating up the gear
Old Nov 11, 2005 | 06:25 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote"> but i wanna see the bearing so that pully needs to get off</TD></TR></TABLE>What bearing?
Old Nov 11, 2005 | 09:17 AM
Default Re: how do you take out the pully from the crank that the t-belt runs off? (2quikmotorwerks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2quikmotorwerks &raquo;</TD></TR><TR><TD CLASS="quote">NO DO NOT HIT THE CRANK OR THE GEAR WITH A HAMMER U'LL RUIN THEM!!! try soaking the gear with wd40 or something similar or maybe try heating up the gear </TD></TR></TABLE>
haha i was joking. so it should just slide off? isnt there a bearing in behind that cover that is held together with about 4 philips screws? this is on a b16 by the way
Old Nov 11, 2005 | 09:45 AM
R-Toyz.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">i think its about a 22tooth pully attached to the crank that spins the timing belt. how does this come off? i somehow got the crank out with it attached to the pully but i wanna see the bearing so that pully needs to get off</TD></TR></TABLE>
Won't it pry off after you soak it with lubricant? Make sure the key is out, the soak that thing in penetrant. Try easing it out with a prybar or fat screwdriver. Or clamp the gear with a pair of vise grips and try to wriggle it free. Last resort I would do is to heat the gear up with a torch.
I've come across a couple of stubborn gears before, but they come out without resorting to drastic measures.
Old Nov 11, 2005 | 09:51 AM
Default Re: how do you take out the pully from the crank that the t-belt runs off? (rtzcom)
how will the pin come out?
Old Nov 11, 2005 | 10:20 AM
fmrprojects's Avatar
gun the bolt out for the crank pulley(use a chain vise to hold it from spinning), slide the key out and the gear for the timing belt should slide off easy
Old Nov 11, 2005 | 11:02 AM
R-Toyz.com's Avatar
Default Re: how do you take out the pully from the crank that the t-belt runs off? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">gun the bolt out for the crank pulley(use a chain vise to hold it from spinning), slide the key out and the gear for the timing belt should slide off easy</TD></TR></TABLE>
I think its the gear itself thats stuck and not the pulley.
Old Nov 11, 2005 | 02:21 PM
yes the gear not the pully
Old Nov 13, 2005 | 11:40 AM
man there has to be a tool. its not coming off. it looks like its pressed on to me.?
Old Nov 14, 2005 | 12:52 PM
R-Toyz.com's Avatar
I'd say torch it
Old Nov 14, 2005 | 03:48 PM
92hondalude's Avatar
Default Re: (rtzcom)
tapping it with a hammer is going to ruin them but heat isnt?
i just taped mine with a hammer not hard. just a little tap just to break it free then i slided it off
Old Nov 14, 2005 | 03:55 PM
NJIN BUILDR's Avatar
Default Re: how do you take out the pully from the crank that the t-belt runs off? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">What bearing?</TD></TR></TABLE>
Like he said "what bearing".
The oil pump is behind that gear.
Old Nov 14, 2005 | 04:20 PM
b16supertuner's Avatar
Default Re: how do you take out the pully from the crank that the t-belt runs off? (NJIN BUILDR)
all you'll see behind that 4 screw cover is the gearsets for the oilpump... no reason for taking it apart, at all.
replace the pump as a whole
Old Nov 15, 2005 | 07:22 PM
xerox445's Avatar
Default Re: how do you take out the pully from the crank that the t-belt runs off? (b16supertuner)
you could use a bearing seperator, and a 2 jaw gear puller if its really on there...
Old Nov 15, 2005 | 11:41 PM
Niles's Avatar
Heating one end of your crank can cause warping...not to mention, there's oil in them thar crankcases... Liquid wrench and check you manual to make sure you didn't forget some stupid little thing
Old Nov 16, 2005 | 05:47 AM
Default Re: how do you take out the pully from the crank that the t-belt runs off? (Niles)
honda technicians say to use a pully puller. it will not just slide off. this is not the crank pully. its the 22th gear the timing belts runs from
Old Nov 16, 2005 | 09:23 AM
xerox445's Avatar
We know what your talking about, and it should just slide right off. Give it a few taps with a rubber mallet or something.
Old Nov 16, 2005 | 01:49 PM
Niles's Avatar
Default Re: how do you take out the pully from the crank that the t-belt runs off? (xerox445)
I'm with xerox on this one, try a bearing puller, put some pulling load on it, then tap it genlty with a rubber hammer, that's what I do to bust rusted brake rotors off, works great. If you don't have a puller, go rent one for $5.
b16civster
May 12, 2007 12:05 PM
Incubus05
Aug 2, 2005 03:51 PM
Soon_2b_evil
Mar 27, 2004 11:07 AM
Sam1am26
Mar 22, 2004 05:24 PM
VisualEcstasy
Apr 22, 2003 02:44 PM
