syncro in gearboxs
Old Mar 10, 2002 | 04:54 PM
Zeus Zore's Avatar
Default syncro in gearboxs
how hard is it 2 change the syncro in the gearbox !?!
anything 2 be aware off ??
the tranny(and rest off the car) has done 162000 miles .. so i think it is about time the shifting are not what it use 2
Old Mar 11, 2002 | 02:21 PM
dwilson's Avatar
Default Re: syncro in gearboxs (Zeus Zore)
Yeah, could anyone help us out. I would like to know as well. I have only been as far as a clutch and rear main seal install in a transmission and would like to know the ups and downs of changing the syncros.
Old Mar 12, 2002 | 04:07 AM
Gasoline Fumes's Avatar
I wouldn't do it without a factory service manual.
Old Mar 12, 2002 | 04:33 AM
92sleepR's Avatar
New User
It can be done by a home mechanic but you must have the Helms manual and you will need a decent hydraulic press to get some of the gears off. You could also take it appart, take the main shaft assembly to a shop and have them change the synchros and then re-assemble the tranny your self, saving all the labor charges which is what makes it so expensive in the first place. This is what i would do (and probably will at some point if I don't learn to shift a little gentler)
Mike
Old Mar 12, 2002 | 05:18 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: syncro in gearboxs (92sleepR)
no press needed, just a tiny hammer and a workmate.
Original poster, why do you think you synchros are bad? What gears are giving you issues? Most likely a shifter fork.
Devon7234
May 6, 2010 05:17 AM
rol1in0n20s
Honda Motorcycles
May 21, 2007 03:30 PM
professorman
Feb 28, 2003 10:30 AM
Fr0m4311
Jun 22, 2002 08:37 PM
rave n race
Jun 27, 2001 12:26 PM
