EM1 Motor mount question..
Old Nov 10, 2005 | 08:21 PM
wantboost's Avatar
Who is Mr Robot?
Default EM1 Motor mount question..
i have a 99 em1. im using the innovative mount kit (upper solid mount, tranny side solid mount and rear solid mount)
my question is this... the mounts are 60A urethane... pretty stiff stuff. can i get away with not using the lower tranny mount in the front and the bracket for where the ac compressor used to mount?
Old Nov 10, 2005 | 10:04 PM
b18ccivics's Avatar
Default Re: EM1 Motor mount question.. (wantboost)
why would you want to
Old Nov 10, 2005 | 10:13 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: EM1 Motor mount question.. (b18ccivics)
because A) the two lower mounts are ugly.. showcar
B) solid urethane in 3 places plus a torque dampener should be more than enough to keep the motor from moving.
http://cgi.ebay.com/ebaymotors...wItem
thats the mount kit im using.... i dont see why they are needed anymore... solid mount in the middle of the motor in the rear keeps it from flexing.. the urethane should be able to stop it from moving without the torque mounts.... but like i said im open to opinions
Old Nov 10, 2005 | 11:04 PM
SuperSi's Avatar
My lower mount is cracked and my car shakes and the shifter moves when I rev my engine. So I dont think so TIM.
Old Nov 10, 2005 | 11:05 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: EM1 Motor mount question.. (SuperSi)
but do you have stock motor mounts all the way around? i dont... mine arent stock... completely solid 60a urethane filled afermarket upper drivers side mount, upper tranny mount and rear mount
Old Nov 10, 2005 | 11:18 PM
SuperSi's Avatar
True. Good luck with your mounts.
Old Nov 11, 2005 | 08:28 AM
wantboost's Avatar
Who is Mr Robot?
anyone else?
Old Nov 11, 2005 | 10:03 PM
wantboost's Avatar
Who is Mr Robot?
so i guess i'll be ok then?
Old Nov 12, 2005 | 01:15 AM
OMG B16's Avatar
No. You. Gay. German. You.
Old Nov 12, 2005 | 07:17 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Sick00SiCoupe)
last time i checked i was faster than you.... you.gay.german.you
Old Nov 12, 2005 | 07:32 AM
DaveF's Avatar
Default Re: (wantboost)
no, you wont be ok..........
you want to put the mounts on. you have 2 mounts that are inline with the crank. you want to use the 2 lowers because it will distribut the power into the chassis/suspension instead of rotating the engine on the center axis... like an engine plate in a sence.
yea, im bad at explaining ****
Old Nov 12, 2005 | 11:01 AM
OMG B16's Avatar
When is the last time your car has ran?
Old Nov 12, 2005 | 11:03 AM
wantboost's Avatar
Who is Mr Robot?
about a year ago... dont forget i have your money in my possession... play nice .
so i guess i need the lower mounts. ill probably use the oem tranny side mount and have it powdercoated.... im thinking about fabbing the ac mount myself
obuhmyuh
26
Nov 5, 2008 02:30 PM
Razr2
18
Mar 15, 2008 08:59 PM
hothotpete
Nov 22, 2004 11:12 PM
TeGGY_LS
Nov 15, 2004 08:19 PM
onyx00
Sep 24, 2004 01:00 PM
