RHS HONDA B-SERIES VTEC HEAD
Old Nov 10, 2005 | 07:46 PM
projectPSI's Avatar
Default RHS HONDA B-SERIES VTEC HEAD
http://www.racingheadservice.c...c.asp
Does anyone have any experiances with these heads? Any info or experiance will be helpful, thanx.
Old Nov 10, 2005 | 07:55 PM
2k.civic.si's Avatar
Default Re: RHS HONDA B-SERIES VTEC HEAD (projectPSI)
bump
Old Nov 10, 2005 | 08:17 PM
projectPSI's Avatar
Also this head has a thincker deck surface. If used with a dart block that also has a taller deck? what does this mean? how will this affect compression and would u need custom rods?
Old Nov 10, 2005 | 08:35 PM
5thgenallmotor's Avatar
Default Re: (projectPSI)
The place I work is getting one soon. The only difference from what i have read is the port walls are thicker to allow for more porting, and it is supposed to be a "better" casting. I would ask Brad from RLZ if they have ever checked this head out. As for the rods, If you had a Tall deck dart then yes you need different rods, As for the head it is basically the same in stock configuration, You would need to cc the head to figure out compression.
Old Nov 10, 2005 | 08:40 PM
1 2 NV's Avatar
Default Re: (5thgenallmotor)
i think these heads might be the ones designed and made by a company out of australia. i cant remember the name of the company. they went **** up and i bet RHS bought all the heads. they are based off a GSR head. i
ve seen one in person if its the head i think it is. casting is a little rough, needs some fine tuning in the machining area but looks decent.
pro topline was the name of the company.
Old Nov 10, 2005 | 09:36 PM
Rocket's Avatar
Default Re: (1 2 NV)
Protopline.
Old Nov 11, 2005 | 05:12 AM
projectPSI's Avatar
bump, so what do we know about pro top line heads? i need the good bad and the ugly.
Old Nov 11, 2005 | 01:18 PM
What do you want to know? I have one in my hand right now. It looks a little different.... I will see if I can get some pics of it up for you. Also it is for sale. PM me if you want.
Old Nov 11, 2005 | 02:07 PM
Ok Here are the pictures (Hopefully, New Hosting site)
Old Nov 11, 2005 | 04:19 PM
NJIN BUILDR's Avatar
They must have paid for their site a few years in advance.Their site never went down. http://www.protopline.com/racingaluminumhonda.htm
Glenn
Old Nov 12, 2005 | 06:55 AM
MAX_CFM's Avatar
Default Re: (Rocket)
I am working on development with RHS .. on these heads ..
Old Nov 12, 2005 | 06:57 AM
projectPSI's Avatar
anyone know the exhaust flows on these?
Old Nov 12, 2005 | 06:59 AM
BERT-O's Avatar
whats the going rate for these? i would think these would be hot item if the price was right?
Old Nov 12, 2005 | 08:11 AM
projectPSI's Avatar
I dont know but im gonna buy one as soon as i figure out what these flow and what the posibilities are. From the protopline site i can see that the intake flows better then alot of the stock port and polished heads do. Still no info on exhaust.
Old Nov 12, 2005 | 04:29 PM
We are in the process of getting a Slider for honda heads for our Superflow 1020 flow bench. So I will flow it when that happens. It won't be for a little while though, After the PRI show.
RLZ (Brad), What do you use to flow Heads? Just Curious if you made your own?
Old Nov 12, 2005 | 06:01 PM
MAX_CFM's Avatar
I use the Brzezinski Acrylic flow cylinders ...
Old Nov 12, 2005 | 06:38 PM
Default Re: (MAX_CFM)
Really, small world I guess. Just took Brzezinski (Randy) a bunch of SBC heads for cores. Real nice guy!
Old Nov 12, 2005 | 07:14 PM
racerboyb18c1's Avatar
hmm any flow charts on these heads stock?
Old Nov 12, 2005 | 09:19 PM
Trooper's Avatar
Default Re: (racerboyb18c1)
Im not shure but the head i saw at SEMA wasnt ported and verry rough, i dont know if it was a production sammple or not,
Old Nov 13, 2005 | 04:58 PM
Default Re: (Trooper)
From what comp cams said the last time I talked with them (which was a while ago now) they were sorting thru what protopline had produced and working on sourcing casting new ones.My guess the ones you saw at sema were the ones protopline produced.
Glenn
Old Nov 13, 2005 | 05:10 PM
projectPSI's Avatar
Im really interested in getting the flow numbers. From what the protopline website specs say this is a bitching head stock and with some work is bad ***. Hope to make some power with this on a dart block. Just need to know if i should get this of if im better of having work done on a stock gsr or b16 head.
Old Nov 13, 2005 | 05:43 PM
Don't get to hung up on advertised flow numbers.Everyone has their own way of flow testing heads.The advertised numbers are usually optimistic.Its rare that I get the numbers on my bench that are advertised.Bench flow numbers are only an indication of hp potential.I have had heads that made good numbers not live up to the numbers on the dyno.But I have had some heads exceed their calc. hp numbers on the dyno.On set in particular by a lot.My experience with the protopline heads (not the honda one,as I never had one) have been that most made good power but needed some close inspection.
Glenn
Old Nov 13, 2005 | 05:45 PM
It will be way cheaper to do your stock head. PM MAX_CFM, he is well known for doing great flowing heads! That is who I would recomend. He would probably know flow #'s on the RHS head as well. Good luck!
Old Nov 14, 2005 | 02:53 PM
projectPSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenallmotor &raquo;</TD></TR><TR><TD CLASS="quote">It will be way cheaper to do your stock head. PM MAX_CFM, he is well known for doing great flowing heads! That is who I would recomend. He would probably know flow #'s on the RHS head as well. Good luck! </TD></TR></TABLE>
Well not cheaper as its hard to find a stock head for 400 and then my guess is like another 600-800 for port and polish. I can get my hands on a rhs head for much less.
Would like to keep the rhs stock and see what power it makes. Then later on do the works on it.
From what it look slike im gonna be the guini pig on this one. Im really curious as to how these heads perform.
Old Nov 14, 2005 | 03:49 PM
My "guess" is that it will not make anymore power than a oem GSR head.They really didn't change much in the design of the ports or chambers.This isn't a bad thing.If you can get one new for $900 ish then I'd go for it.Protopline had a billet cap option.Do these have the billet caps?
Glenn
