what psi should i run on it ?
Old Nov 10, 2005 | 06:54 PM
twisted_jdm_b16's Avatar
Default what psi should i run on it ?
i have a jdm b16 Sir II with stock internals . im goin to be using a t25 from a nissan . how many pounds of boost should i run on it withough messing anything up on my engine ? i want to run as high as possible without any damage to engine .
Old Nov 10, 2005 | 07:03 PM
jeff420's Avatar
Default Re: what psi should i run on it ? (twisted_jdm_b16)
1000 psi...
no but seriously, do a search. theres alot of topics on this. dont worry about how much boost, but how much hp. now go and search.
Old Nov 10, 2005 | 07:05 PM
KeyserSoze's Avatar
Default Re: what psi should i run on it ? (jeff420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeff420 &raquo;</TD></TR><TR><TD CLASS="quote">1000 psi...
no but seriously, do a search. theres alot of topics on this. dont worry about how much boost, but how much hp. now go and search.</TD></TR></TABLE>
^^^ x2
400hp would be about your max, but you will get no where near that with that turbo. Search, learn, READ THE FAQ's. There is soo much info in the faq's, you would be amazed. GL.
Old Nov 10, 2005 | 10:21 PM
Squad1's Avatar
im boosting only 7psi on mine..
stock .. bone stock... no nothing
Old Nov 10, 2005 | 10:24 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: what psi should i run on it ? (Squad1)
by nothing do you mean fuel management as well? if you arent running any fuel management on your car please go end yourself and give me your car before you break it
Old Nov 13, 2005 | 04:34 PM
Default Re: what psi should i run on it ? (wantboost)
im goin to be running dsm injectors along with a vafc for alittle till i save up and get a better fuel management unit . i dont really want to run any higher than 7psi on my stock internal b16 . by the way what are nissan t25 turbo wastegates set at ?
Old Nov 13, 2005 | 04:45 PM
dpetro1's Avatar
like some of the others said. its more about how much hp you are making not how much psi, even though they are related. 10 psi on a t25 wil make less power than 10spsi on something big like a gt40r. so i would shoot for about 300whp to be safe. (many have gone higher)
and as far as the vafc goes, that is probably the worst way to manage your fuel system, especially for boost. i would suggest not even wasting your money on it and just buy a chipped ecu and use one of the more affordable ems software. hit up the archives for more info
Old Nov 13, 2005 | 04:47 PM
_gurusan_'s Avatar
Default Re: what psi should i run on it ? (dpetro1)
I wouldn't use a t25 on a b16.
It will die out in the higher RPMs and just be blowing hot air
Old Nov 13, 2005 | 05:14 PM
Default Re: what psi should i run on it ? (_gurusan_)
i actually picked up that turbo and a intercooler from a friend for $85 . well i know this turbo is small but i want to get as much out of it as i can with still being safe internally . as for the VAFC , i already have one hooked up at the moment.
leinadmiih00
Jun 7, 2006 10:42 PM
dc2sick
Sep 19, 2005 06:04 AM
boosted k20
Mar 8, 2005 01:31 PM
T3-T4TEG
Apr 21, 2004 04:01 PM
zseeanz
Nov 16, 2003 07:56 PM
