Has anyone ported a Skunk 2 IM? p72 head..
The reason I ask this is cause I'm planing on porting either a stock gsr intake manifold or my skunk 2 manifold I have on currently. Which do you think would be more worth while? After seeing the gain the TSR integra got from porting the IM, I leaning towards doing this. My head is fully ported so I presume it would use the extra cfm while maintaining air velocity. What do you think?
I thought Endyn did a full write up on the ported manifold. If not they at least talk about it in this link and show some before/during/after pics. http://www.theoldone.com/articles/badtothebone/
...Thanks for the link. I always thought it was an R manifold that they ported. I plan on starting this soon considering the car is parked now(winter).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">After seeing the gain the TSR integra got from porting the IM, I leaning towards doing this. </TD></TR></TABLE>
have a link to this or any more info?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 »</TD></TR><TR><TD CLASS="quote">yo, with the cams you have, you'll lose power. you'll need a higher lift cam to aid with the added cfm from hogging out that im. </TD></TR></TABLE>
Understood. I'm considering getting some different cams but I'm not 100% sure yet as funds are low. I would like to cut up this mani and start porting it. I wonder if the duration on the bc3+ will make up for the mild lift.
Is anyone running a mild lift cam with a ported IM, with any sucess? Results?
Twenty36_1
Aug 5, 2004 10:56 PM
