can I hone a b18 block, and still run JDM ITR STD size pistons???
Old Nov 10, 2005 | 04:05 PM
92integraVTECgsr's Avatar
Default can I hone a b18 block, and still run JDM ITR STD size pistons???
Old Nov 10, 2005 | 04:15 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: can I hone a b18 block, and still run JDM ITR STD size pistons??? (92integraVTECgsr)
Are your cylinder walls damaged that much?
Old Nov 10, 2005 | 04:17 PM
Default Re: can I hone a b18 block, and still run JDM ITR STD size pistons??? (shamoo)
not sure.. thats what i thought i heard before that depends on how bad the cylinder walls are.. just wanted to confirm that.
I am buying a b18a from a guy and right now i can get some cheap JDM ITR STD pistons brand new with pins and rings. just wanted to know before i bought them, or just wait till i find out the condition of the block. which is probably best, but i dont wanna miss out on a good deal.
Old Nov 10, 2005 | 04:21 PM
shamoo's Avatar
Might want to confirm how much, if any, damage there is on the cylinder walls before you buy anything. If there's nothing really, then a light hone job will be fine. Anything more and you'll have to hone/bore it to repair it. Obviously then you wouldn't be able to use those pistons.
Old Nov 10, 2005 | 04:50 PM
mmuller's Avatar
Mad Scientist
If there is lots of miles on the block; you most likely almost sure are going to have to step up to the next size up; even if the walls look great the cylinders are going to be egg shaped and your piston to wall clearances are going to be off specs
Old Nov 10, 2005 | 05:29 PM
Default Re: can I hone a b18 block, and still run JDM ITR STD size pistons??? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">If there is lots of miles on the block; you most likely almost sure are going to have to step up to the next size up; even if the walls look great the cylinders are going to be egg shaped and your piston to wall clearances are going to be off specs</TD></TR></TABLE>
Good Point
92integraVTECgsr
Jan 16, 2006 11:59 AM
fastcivicboy
Mar 21, 2005 08:51 AM
LSVtechnologytur...
Oct 25, 2004 08:02 PM
AbaZ
Apr 6, 2004 04:54 PM
speedy108
Nov 25, 2002 07:24 PM
