Fouled Spark Plug
Old Mar 10, 2002 | 03:48 PM
sivicman's Avatar
Default Fouled Spark Plug
I have a '92 Civic VX with a stock D15Z1 engine with 125K miles on it. I bought the car brand new and ever since day one the #4 spark plug is always fouled out.
I've taking the car to two different Honda dealers several times and they said everything checks out fine. Could this be a bad fuel injector from the factory? The car runs and idles fine.
Old Mar 11, 2002 | 09:10 AM
WOTTEG's Avatar
Default Re: Fouled Spark Plug (sivicman)
If the plug is fouled, it won't fire regularly, or won't fire at all. I'm pretty sure you'd notice this. [Backfiring]
I'd try adjusting the plug wire that goes to #4. I've seen a bad plug wire cause a cylinder to not fire. Just moving it, wiggling it will help sometimes. (It did on my friend's 350)
Hopefully this helps.
Old Mar 11, 2002 | 11:12 AM
976's Avatar
976
New User
Default Re: Fouled Spark Plug (WOTTEG)
Poor fuel injector, valves, or gaskets... I wouldn't be to worried, try some fuel injector cleaner, and start using higher octane fuel.
[Modified by w00t!, 8:12 PM 3/11/2002]
Old Mar 14, 2002 | 04:22 AM
sivicman's Avatar
Default Re: Fouled Spark Plug (w00t!)
I replaced the wires, and that didn't help. If I replace the injectors don't they have to be a matched set? I keep the valves adjusted every 15K like the service manual says to.
Old Mar 15, 2002 | 03:58 AM
kkim's Avatar
no, you can replace the injectors one at a time. I had injector problems on my 92 ex sedan. when the injector went, it ran like crap... like on 3 cylinders... which it was, come to think of it. new injectors run about $50-60 each. I got mine form mancheseter honda... but any online honda parts place is good. you might want to try this site for parts...
http://www.acuraautomotiveparts.net/
good luck.
Ash J. Williams
Feb 17, 2013 07:14 PM
slowwcivic
May 25, 2011 06:18 AM
deraj1986
May 30, 2010 01:28 PM
virusiidx
Jan 18, 2005 10:11 AM
Kamin
Aug 3, 2002 12:08 PM
